Library in different location then Plex
How do I use a Library that is on a different drive to where Plex is installed? I am on Ubuntu 20.04 and I have tried changing the group of the folder I want to access to Plex but only the top level drive appears when I navigate to it… nothing in the right-hand side of the add media box.
Server Version#: Version 1.30.2.6563
Thanks,
Aaron
I can’t get the movies to appear! I have put the mount stuff in the fstab and checked to see if it mounts ok which, it does. However, when I go to the location in Plex only the folder will display. None of the movies within the folder get detected when I can the location. If I put they in the default Plex folder (Library?) it works. However, this is not an option due the amount of media files and the size of the hard drive.
@spehr_aaron_gmail_com
Where do you store your actual media ?
You can use internal , external USB, or network locations.
I have my media on an other internal disk.
COOL.
This is easily done.
  1. Decide on a mount point which isn’t anything already existing.
  2. sudo mkdir /mountpoint
  3. sudo chmod 755 /mountpoint ( sets the base directory permission)
  4. sudo mount /dev/sdXY /mountpoint (manual mount)
And now for the often-missed trick.
  1. sudo chmod 755 /mountpoint (sets the permission of the mounted filesystem)
Lastly, in /etc/fstab, add the line for the device (something like this)
Change <fs-type> to be ext4, xfs, ntfs, etc as appropriate
/dev/sdxx /mountpoint   <fs-type>  defaults,auto 0 2
  1. sudo umount /mountpoint ( unmount it )
  2. sudo mount /mountpoint (confirm fstab works as desired)
Now go look in there with Plex.
If you can’t see down very far, fix those permissions as well with ‘chmod’.
I was able to get it to display installing Plex via Docker with help from this article.
