There are a bunch of these so I apologize in advance.
The Media Storage is an External Drive that was on my windows installation.
Currently Formatted to ntfs as it would be.
Looking through other posts I (am dumb at the linuxes) Set the mount point to /media/externaldrive
I added the UUID in fstab as
UUID=66D22E98D22E6C8D /media/externaldrive ntfs defaults,permissions,auto 0 1
as one post mentioned
I also changed the ```
/etc/default/plexmediaserver username to MY username instead of plex
I did a chown -R [My Username] on the drive at the mountpoint
I probably missed a step somewhere in any one of these posts and decided I may need more guidance than my ability to follow directions led me to believe.
I CAN Currently select individual folders from the external drive when adding a library at this point. However, when “Scanning Library Files” finishes, the app shows there are no items in the library.
Used /media . This is reserved by the Gnome desktop. You wouldn’t have known. It puts things there so it would make sense but it doesn’t work when another user (plex) needs to access the files
/etc/defaults/plexmediaserver has been obsolete since June 2016 when systemd became the Linux standard control process for Debian 8, Ubuntu 16, and Fedora.
This “works on my machine”, so you may need to overcome some hiccups.
Here it did not work immediatly, because the scanning took a while and my Browser crashed after high CPU usage. After I restarted my computer, Chrome crashed again (I guess Plex was still doing a lot of work with tagging)
I tested if VLC can still play my music files → works
After my third start up of the plex web player, it finally was running
Album Covers still where updating in the background from the artists profile pic to the actual album cover → plex really does a lot in the background
German to English translated freely and may differ in reality
I hope this will help you set up your media-library on linux with external drives as a regular user
