Library is Reset on Reboot of unRAID and new instance is created
Each time I’m forced to reboot my unRAID machine (like to add more hard drives) I lose my entire Plex Library the next time I boot it up. It shows up as a whole new Plex Server device in my Plex Devices list. How do I prevent this from happening and having to redo all of the work to customize my Plex library? And is there a way to roll back to a previous library?
Technical Details:
No static IP
Running Plex from the Docker version 1.4.3.3433-03e4cfa35 with auto-update turned on
/config path is pointing to /mnt/user/appdata/PlexMediaServer and it has full read/write/execute permissions
unRAID version 6.3.0rc1 and I’m using the WebGUI to access it on the same machine
Running on Linux 4.7.6-unRAID x86_64
8GB memory
Intel Core i7 CPU 870
Cache 8192kB
logged in as root user each time
/appdata is set up as a share with all files protected
I have 3 5TB drives installed, one for parity, two for storage. I also have a 120 GB solid state Cache drive.
Here is a screenshot of what it looks like in my Plex Devices List:
I’m having this problem as well. Did you find a solution?
