Library navigation forgets active library
In scenarios where you have more than one available library for Films for example, and you are currently in the nth library (not the first one), when navigating up you can often inadvertently switch to the first library.
Suggestion is for the user interface to remember which library you are navigating and to keep the active library selected so that users don’t find themselves in the wrong library by mistake.
