Library Search Not Working for Local Content
Server Version#: Version 1.41.5.9522
Player Version#: Version 4.145.1
Plex Media Server Logs_2025-03-19_22-57-40.zip (3.9 MB)
The global search function in Plex is not working for items in my libraries. It will return results from shared libraries and Free On Demand, but not from my local server. This must have been a recent issue because I use the search often. It has even stopped working in Plexamp for my music which does not return any results. Not sure what could have caused this, but I did update the Plex server software not too long ago.
Mar 19, 2025 21:41:59.490 [22364507474744] DEBUG - [DatabaseFixups] Collections: Found 1 collections tags in section 6.
Mar 19, 2025 21:41:59.492 [22364507474744] DEBUG - [DatabaseFixups] Collections: We had 1 collections in the library already.
Mar 19, 2025 21:41:59.492 [22364507474744] DEBUG - [DatabaseFixups] Collections: Synced tags in section 6 in 2ms.
Mar 19, 2025 21:41:59.499 [22364507474744] ERROR - [DatabaseFixups] SQLITE3:0x80000001, 11, database corruption at line 84326 of [a29f994989]
Mar 19, 2025 21:41:59.499 [22364507474744] ERROR - [DatabaseFixups] SQLITE3:0x80000001, 11, statement aborts at 11: [SELECT idx, start_block, leaves_end_block, end_block, root FROM 'main'.'fts4_metadata_titles_icu_segdir' WHERE level = ? ORDER BY idx ASC] database disk image is malformed
Mar 19, 2025 21:41:59.499 [22364507474744] ERROR - [DatabaseFixups] SQLITE3:0x80000001, 11, statement aborts at 186: [update metadata_items set extra_data=? where library_section_id=? and metadata_type=? and metadata_items.extra_data not like '%at^%3Asmart=1%' escape '^' and id not in (236353)] database disk image is malformed
Mar 19, 2025 21:41:59.500 [22364507474744] ERROR - [DatabaseFixups] Exception inside transaction (inside=1) (/home/runner/_work/plex-media-server/plex-media-server/Library/MetadataCollection.cpp:519): sqlite3_statement_backend::loadOne: database disk image is malformed
Mar 19, 2025 21:41:59.500 [22364507474744] ERROR - [DatabaseFixups] Fixup 29DatabaseFixupsSyncCollections threw an exception: sqlite3_statement_backend::loadOne: database disk image is malformed
Mar 19, 2025 21:41:59.567 [22364563663672] INFO - Running migrations. (EPG 1)
Mar 19, 2025 21:41:59.569 [22364563663672] DEBUG - Captured session 0.
Mar 19, 2025 21:41:59.569 [22364563663672] DEBUG - Captured session 1.
Mar 19, 2025 21:41:59.569 [22364563663672] DEBUG - Captured session 2.
Database is corrupted. This is why search isn’t working
Your choices to repair are:
https://support.plex.tv/articles/repair-a-corrupted-database/
or
Thank you! Restoring the database to the prior scheduled backup worked. :grinning_face:
I’m so happy that it was that easy.
