Library something went wrong
Server Version#: 4.142.1
Player Version#: Plex Web—Player
I have an error loading one specific library, which always displays “something went wrong”.
I had it on 2 libraries, done optimize database, clean bundles, and empty trash from all libraries. It was able to correct one of the libraries.
Currently i still have one library that i can see the “recommended” tab but can’t on the “library” tab.
On the console i can see there are database errors
can theese be corrected?
Do I need to delete and recreate the library?
If it still says “database is malformed”, then it is still damaged.
Have you tried this .bat file? PlexDBRepair/Windows at master · ChuckPa/PlexDBRepair · GitHub
used DBRepair-Windows.ps1 option 2 fix repair automaticaly and library is accessible.
Lost a couple of metadata, easily corrected by fixing match.
Thank you for the help.
