Server Version#: 1.40.4.8679
Player Version#: 1.97.2.190-ca5000d0
Why am I getting this warning over and over? Each time it comes up I press “Upgrade” and 10 minutes later it comes back.
May we see your server’s DEBUG log files ZIP which you download a few minutes after hitting the Upgrade?
I suspect there’s corruption in the DB causing a problem.
(We can fix some of that. It depends on what & how bad)
Hi, thanks for the reply. I ended up deleting the TV library and creating a new one. That seems to have fixed the problem
