Just wondering if there was any changes to the lircmapping in the latest version?
I got the OTA update last night and after that the Menu button on my apple remote doesn’t work as a back button anymore, instead it shows a menu (doh! :D)
should I change KEY_MENU to KEY_MENU instead?
@Naesstrom said:
I’ll answer my own post if anyone else run into the same problem as I did.
SSH into your rasplex and run nano /storage/.plexht/userdata/Lircmap.xml
Replace the line <menu>KEY_MENU</menu>
with <back>KEY_MENU</back>
ctrl-x and save/overwrite then reboot and everything works again.
Hi Naesstrom… I fresh installed rasplex 1.7.1 on my raspberry pi3 and hooked up an ir receiver in order for my apple remote (A1294) to work. I followed the official installation guide from this forum and all went smoothly. But I have almost the same problem with you. The “KEY_MENU” button doesn’t give the “stop” command while a movie is playing, but instead it shows the info bar. I made the modification you suggested but the problem still exists. Do you have any idea what the problem might be? Thx in advance.
What section of the xml did you add it? Needs to be in fullscreen or global subsections.
Oh Im no pro at this but I never used the menu button to stop, you start and stop with the play button (its marked with a play and paus icon). Once paused you can go back with the menu button.
@benjaminwolf Here is an Debug log with this issue for you:
Exactly in the middle of Debug logging ON and OFF
Thats what i to in this time…
Enable Debug logging
Go to Movies an Press Play
When the Movie Runs i Press the Menu Button
I am Back in Movie library
Go back to Home, See that the Playback is running
klick an “Playback” and press “PlayPause” than “Stop”
Ge back to Settings and Disable Debug logging.
Thats my lircd.conf
begin remote
name appleremote
bits 8
flags SPACE_ENC|CONST_LENGTH
eps 30
aeps 100
header 9048 4434
one 586 1634
zero 586 536
ptrail 584
pre_data_bits 16
pre_data 0x77E1
post_data_bits 8
post_data 0x78
gap 107001
toggle_bit_mask 0x0
begin codes
KEY_UP 0xD0
KEY_DOWN 0xB0
KEY_LEFT 0x10
KEY_RIGHT 0xE0
KEY_OK 0xBA 0x20
KEY_EXIT 0x40
KEY_PLAYPAUSE 0x7A 0x20
end codes
end remote
@Massaguana said:
The best solution would be if the OpenPHT Team found a solution…Until then the remote.xml can help…
I suspect that the remote.xml is deleted during an update
Were you using a remote.xml previously but it was deleted during the update? All my keyboard.xml files survived. I think this might be related to another change in the last build.
@benjaminwolf said:
Can someone upload a debug log of you pressing the menu button? We need to know what OpenPHT is seeing when that happens.
Feels like a stupid question but I’ve used all my google skills and still havn’t found the answer, where can I find the debug log?
Noticed now (or rather my wife did) that when playing something and pressing the menu button it brings you back to the episode screen but don’t stop the media from playing
Earlier the menu button worked like this, if something was playing and you pressed it it brought up the plex menu with the play, pause, subs etc. one more press and the menu went away. If the media was paused and you pressed the menu button it instead exited back to the selection screen.
In general, the log file for the various Linux versions of Plex Home Theater will be found under:
~/.plexht/temp/
You need to copy either the:
plexhometheater.old
or
plexhometheater.log.old
If Rasplex/OpenPHT has restarted from crash or reboot then copy the “plexhometheater.old.log”.
If Rasplex/OpenPHT is still running while you are debugging then copy “plexhometheater.log”.
Put the contents in pastebin. To do this:
Either:
Copy the contents of the log file and paste into http://pastebin.com/ Give it a Paste Name / Title Click SUBMIT button. It will then sho wyou the resultinging paste bin page. Copy the URL (eg http://pastebin.com/a4PLs1mX) to include with your bug report.
Or:
Using a pastebin script or by copying the output of “cat” from the buffer.
A very useful way to trim down the logs is “grep -i error /(full path to logs)/plexhometheater.log” to submit only errors.
I think that you will run into issues if you run both commands at the same time. The better way is to program them to have different functions deppending on the menu you are.
But if you want to run two commands at the same time, make the MENU button run a script and in that script use xbmc-send to pass both commands
