Hey together,
i just installed plex an have tested them a little bit. I am missing a possibility to listen to an internet radio channel. Is there a simple possbility to add some internet radio channels to my library?
Thanks a lot
Greets Eddie
Hey together,
Thanks a lot
Greets Eddie
I have installed the old radio set plugin. I have customized this plugin for my radio channels and installed this plugin for each radio channel i need. ( i copied the plugin folder, renamed him and customized the code)
