Live TV (audio only channels) fail to play
DVB-T Audio Only channels no longer work on Plex Android TV App.
Tested on all DVB-T Audio channels but 027 ABCCMENZ (ABC Classic) is an example.
Error - An error occurred while attempting to play this video. Please check your connection and try again.
shield_plex_logs_24_03_24.txt (4.0 MB)
Tested on macOS Plex app - works fine.
Server Version#: 1.40.1.8227
Player Version#: 10.11.0.183
Device: Shield Android TV (P2897)
Device OS: Android 11 - 9.1.1 (33.2.0.157)
Tuner Make/Model: HDHomeRun CONNECT QUATRO
Tuner Model: HDHR5-4DT
Guide/Lineup name: Freeview - Melbourne
Using XMLTV?: No
Channel number/Name: 027 ABCCMENZ (ABC Classic)
Did you find a fix, same problem here…
just checked again and issue still persists on my Android devices (Shield & FireTV) with error: “An error occurred while attempting to play this video. Please check your connection and try again.”
Plex app for macOS and iOS plays them fine. Perhaps one of the Android devs could look at this if @BigWheel @ChuckPa could flag it with them.
Unfortunately i do not have a tuner that picks up any audio only channels to try to reproduce but thanks for logs. I’ll make a report
If this is simple to reproduce is it possible to get the server logs as well as the android tv logs covering the same playback attempt so I can add them both to report
shield_logs.zip (387.8 KB)
thanks @BigWheel
Do y’all know how to use curl? wanted to know if y’all can run this command to save a file from the stream.
curl http://x.x.x.x.:5004/auto/v1 --output test.mpg
where x.x.x.x is your tuner IP address
and v1 where 1 is the channel number. so v27 for channel 27
can you them put it on DropBox or something similar and message me a link to it.
Sample as requested.
DVB_T_Audio_Sample.mpg.zip (1.6 MB)
Codec: MPEG Audio layer 1/2 (mpga)
Language: English
Type: Audio
Channels: Stereo
Sample rate: 48000 Hz
Bits per sample: 32
Bitrate: 256 kb/s
Here are two examples from my area (only Czech stations are available as audio-only).
audio_only_ts_streams.zip (800.1 KB)
