Live TV doesn't work with one specific show
If I try to record Sunday Brunch on Sunday Morning, 9:30 Channel 4 UK it does not work. Many months ago it would work intermittently, but often split the show into parts or record only the first hour. for months now it just ignores the show and doesn’t record it.
The show is in the Guide and it is set to record on the guide - if I go to the Guide Listings it’s there in the guide and set to record. However, the schedule tab lists it but says no upcoming airings, which is odd because this show is pretty much on every single Sunday of the year (including the coming Sunday).
Other shows record fine, but this one has never recorded reliably. Currently it doesn’t record at all. Can anyone help? I can supply the right log file, if someone points me to it.
Server Version#: 1.23.5.4841
Player Version#: n/a
Tuner Make/Model: HD HomeRun Connect Duo
Guide/Lineup name: Don’t know
Using XMLTV?: Don’t know
Channel number/Name: Channel 4 HD - Channel 104 Freeview
