Doesn't Record One Programme - Sunday Brunch
Everything I set to record works except One show. It’s on Channel 4 on Sunday mornings at 9:30am for 3 hours. It used to work but stopped a few weeks’ ago. Now it doesn’t record it, but it will play it live. If I attempt to record while watching it live it doesn’t record anything.
Can anyone help/provide an update?
Server Version#: Latest
Player Version#: Latest
Tuner Make/Model: Silicon Dust HD Homerun Duo
Guide/Lineup name: UK Freview
Using XMLTV?:
Channel number/Name: 104
I think this is related to the EPG. When I try to record the show it seems to work but claims there are no future airings - even though I’m adding it from the guide the day before. None of my other DVR recordings have this issue - they all see future airings,
I discovered why this didn’t work. It seems that the setting to only record new shows doesn’t work with this show, which is a recurring weekly show (that never or rarely has a break all year long). If I set it to record all airings then it works. I guess this is to do with how it’s tagged in the EPG.
