Server Version#: 1.23.2.4656
Player Version#: 4.58.1
Tuner Make/Model:
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Sometimes the Movies > By Airing view in Live TV & DVR > Browse will show the movies in airing order but will not show the airing time. This seems to happen if the following is done:
- Open the Live TV & DVR > Browse tab
- Change the view to Episodes
- It should default to the Airing order, change it to this if it doesn’t
- Change the view to Movies
This will default to the Airing order, but without the airing time being shown (there is a Genre filter in the below screenshot, but this makes no difference):
If you then change the sort order to Name order and back to Airing, they will show correctly:
