Live TV Failing
Server Version#: 1.18.1.1973 on Ubuntu 18.04.3 LTS with a Hauppauge quad
Player Version#: Happens across all players
LiveTV was working fine a week ago, but now my LiveTV and Recording are now consistently failing. Below are the logs. Any idea what could be going wrong here?
Oct 28, 2019 16:52:36.330 [0x7f07fd7fa700] INFO - [I] web_service_t::process_start_channel (device compound_device093dvb#v4l#/sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:14f1:8880, channel triplet://0:3085:1)
Oct 28, 2019 16:52:36.330 [0x7f07fd7fa700] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:14f1:8880)
Oct 28, 2019 16:52:36.330 [0x7f07fd7fa700] INFO - [I] dvb_device_factory_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:14f1:8880)
Oct 28, 2019 16:52:36.330 [0x7f07fd7fa700] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Oct 28, 2019 16:52:36.332 [0x7f07fd7fa700] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Oct 28, 2019 16:52:36.337 [0x7f07fd7fa700] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Oct 28, 2019 16:52:36.341 [0x7f07fd7fa700] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter2/frontend0
Oct 28, 2019 16:52:36.345 [0x7f07fd7fa700] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter3/frontend0
Oct 28, 2019 16:52:36.349 [0x7f07fd7fa700] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:0, Name LG Electronics LGDT3306A VSB/QAM Frontend, Standards 24
Oct 28, 2019 16:52:36.349 [0x7f07fd7fa700] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:1, Name LG Electronics LGDT3306A VSB/QAM Frontend, Standards 24
Oct 28, 2019 16:52:36.349 [0x7f07fd7fa700] INFO - [I] device_manager_t::get_device_list. Device LG Electronics LGDT3306A VSB/QAM Frontend, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:0, tuners 1, state 0, standards 24
Oct 28, 2019 16:52:36.349 [0x7f07fd7fa700] INFO - [I] device_manager_t::get_device_list. Device LG Electronics LGDT3306A VSB/QAM Frontend, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:1, tuners 1, state 0, standards 24
Oct 28, 2019 16:52:36.349 [0x7f07fd7fa700] INFO - [I] web_service_t::process_start_channel. Trying start channel triplet://0:3085:1 on device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:0 (idx 0 out of 2 available)
Oct 28, 2019 16:52:36.349 [0x7f07fd7fa700] INFO - [I] device_manager_t::add_streamer. Channel triplet://0:3085:1, device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:0, streamer id 665327d5-d364-43e9-a370-156d59b5bc85
Oct 28, 2019 16:52:36.349 [0x7f07fd7fa700] INFO - [I] device_reactor_t::create_device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:0
Oct 28, 2019 16:52:36.349 [0x7f07fd7fa700] INFO - [I] device_manager_t::add_streamer. Adding new streamer container for channel triplet://0:3085:1 on device device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:0.
Oct 28, 2019 16:52:36.350 [0x7f07fd7fa700] INFO - [I] transponder_streamer::start_idle_timer
Oct 28, 2019 16:52:36.350 [0x7f07fd7fa700] INFO - [I] tvs_program_streamer::tvs_program_streamer. Select program for nid 0, tid 3085, sid 1
Oct 28, 2019 16:52:36.350 [0x7f07f77fe700] INFO - [I] streamer_container_t::control_thread. Added streamer 665327d5-d364-43e9-a370-156d59b5bc85
Oct 28, 2019 16:52:36.350 [0x7f07f77fe700] INFO - [I] streamer_container_t::control_thread. First streamer was added. Start program streamer
Oct 28, 2019 16:52:36.350 [0x7f07f77fe700] INFO - [I] dvb_program_streamer_t::start. Starting program streamer for channel triplet://0:3085:1
Oct 28, 2019 16:52:36.350 [0x7f07f77fe700] INFO - [I] transponder_streamer::start_channel. Start request for channel triplet://0:3085:1
Oct 28, 2019 16:52:36.350 [0x7f07f77fe700] INFO - [I] transponder_streamer::stop_idle_timer
Oct 28, 2019 16:52:36.400 [0x7f07cbfff700] INFO - [I] find_device_by_path. searching for matching tuner with device path /sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:0
Oct 28, 2019 16:52:36.400 [0x7f07cbfff700] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Oct 28, 2019 16:52:36.403 [0x7f07cbfff700] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Oct 28, 2019 16:52:36.407 [0x7f07cbfff700] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Oct 28, 2019 16:52:36.412 [0x7f07cbfff700] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter2/frontend0
Oct 28, 2019 16:52:36.416 [0x7f07cbfff700] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter3/frontend0
Oct 28, 2019 16:52:36.419 [0x7f07cbfff700] INFO - [I] find_device_by_path. Found device index 2 for device path /sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:0
Oct 28, 2019 16:52:36.419 [0x7f07cbfff700] INFO - [I] Starting tuner 2, frontend 0
Oct 28, 2019 16:52:36.529 [0x7f07cbfff700] INFO - [I] tuner 2, frontend 0 was opened successfully
Oct 28, 2019 16:52:36.529 [0x7f07cbfff700] INFO - [I] detected tuner ids: vendor (14f1), product (8880)
Oct 28, 2019 16:52:36.529 [0x7f07cbfff700] INFO - [I] No ca0 node is present for tuner 2
Oct 28, 2019 16:52:36.529 [0x7f07cbfff700] INFO - [I] CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 22, modulation 0, polarization 0, symbol rate 0, LOF 0, LNB selection signal 0, FEC 0
Oct 28, 2019 16:52:36.529 [0x7f07cbfff700] INFO - [I] Tuning request. 22, 0, 0, 0, 0, 0, 0
Oct 28, 2019 16:52:36.539 [0x7f07cbfff700] WARN - [W] CV4lTunersStreamSrc::Start. pthread_setschedparam failed 1
Oct 28, 2019 16:52:36.539 [0x7f07f6ffd700] INFO - [I] Starting streaming thread for tuner 2, frontend 0
Oct 28, 2019 16:52:36.540 [0x7f07f6ffd700] INFO - [I] tuner 2, demux 0. adding PID 20
Oct 28, 2019 16:52:37.296 [0x7f07f77fe700] INFO - [I] transponder_streamer::tune_transponder_impl. Signal stats: 0, 0, 0
Oct 28, 2019 16:52:37.297 [0x7f07f67fc700] INFO - [I] tvs_program_streamer::tuning_thread. Starting tuning thread for program triplet://0:3085:1
Oct 28, 2019 16:52:37.297 [0x7f07fd7fa700] INFO - [I] web_service_t::process_start_channel. Successfully started channel triplet://0:3085:1 on device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:0
Oct 28, 2019 16:52:37.297 [0x7f07f67fc700] INFO - [I] tvs_program_streamer::SetPATScanState. Waiting for PAT...
Oct 28, 2019 16:52:37.299 [0x7f07f5ffb700] INFO - [I] http_streamer_t::send_thread_func: adding http client
Oct 28, 2019 16:52:37.346 [0x7f07cbfff700] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 0, client triplet://0:3085:1
Oct 28, 2019 16:52:37.349 [0x7f07f6ffd700] INFO - [I] tuner 2, demux 0. adding PID 0
Oct 28, 2019 16:52:37.397 [0x7f07cbfff700] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 1, client triplet://0:3085:1
Oct 28, 2019 16:52:37.400 [0x7f07f6ffd700] INFO - [I] tuner 2, demux 0. adding PID 1
Oct 28, 2019 16:53:01.321 [0x7f07feffd700] WARN - [E] http_streamer_t::handle_read: read_error: End of file (2)
Oct 28, 2019 16:53:01.322 [0x7f0804a79700] WARN - [E] http_streamer_t: http write error
Oct 28, 2019 16:53:01.322 [0x7f07f5ffb700] INFO - [I] http_streamer_t::send_thread_func: removing http client
Oct 28, 2019 16:53:01.322 [0x7f07f5ffb700] INFO - [I] http_streamer_t::send_thread_func: all clients are deleted. Setting exit flag
Oct 28, 2019 16:53:01.332 [0x7f07f77fe700] INFO - [I] streamer_container_t::control_thread. Removed disconnected streamer 665327d5-d364-43e9-a370-156d59b5bc85
Oct 28, 2019 16:53:01.332 [0x7f07f77fe700] INFO - [I] streamer_container_t::delete_streamer. Last streamer was deleted. Stop program streamer
Oct 28, 2019 16:53:01.332 [0x7f07f77fe700] INFO - [I] dvb_program_streamer_t::stop. Stoping program streamer for channel triplet://0:3085:1
Oct 28, 2019 16:53:01.332 [0x7f07f77fe700] INFO - [I] transponder_streamer::stop_channel. Stop request for channel triplet://0:3085:1
Oct 28, 2019 16:53:01.351 [0x7f07f67fc700] INFO - [I] tvs_program_streamer::tuning_thread. Finished tuning thread for program triplet://0:3085:1
Oct 28, 2019 16:53:01.401 [0x7f07cbfff700] INFO - [I] CTVSStreamSource::RemoveAllPids. Removing PIDs for client triplet://0:3085:1
Oct 28, 2019 16:53:01.401 [0x7f07f77fe700] INFO - [I] transponder_streamer::start_idle_timer
Oct 28, 2019 16:53:01.403 [0x7f07f6ffd700] INFO - [I] tuner 2, demux 0. Deleting PID 0
Oct 28, 2019 16:53:01.413 [0x7f07f6ffd700] INFO - [I] tuner 2, demux 0. Deleting PID 1
Oct 28, 2019 16:53:01.685 [0x7f0805a7b700] INFO - [I] device_manager_t::idle_timer_func. Stream container for channel triplet://0:3085:1 on device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:0 is idle. Deleting it.
Oct 28, 2019 16:53:06.353 [0x7f07f57fa700] INFO - [I] Stopping graph
Oct 28, 2019 16:53:06.362 [0x7f07cbfff700] INFO - [I] Stop device request for tuner 2, frontend 0
Oct 28, 2019 16:53:06.386 [0x7f07f6ffd700] INFO - [I] Exiting streaming thread for tuner 2, frontend 0
Oct 28, 2019 16:53:07.705 [0x7f0805a7b700] INFO - [I] device_manager_t::idle_timer_func. Device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:01.0/0000:03:00.0/0000:04:02.0/0000:06:00.0:0 is idle. Unloading it.
Oct 28, 2019 16:53:07.705 [0x7f0805a7b700] INFO - [I] transponder_streamer::stop_idle_timer
Oct 28, 2019 16:53:07.705 [0x7f0805a7b700] INFO - [I] CTVSStreamSource::Term. Waiting for streaming thread to stop
Oct 28, 2019 16:53:07.742 [0x7f07cbfff700] INFO - [I] Stop device request for tuner 65535, frontend 0
Oct 28, 2019 16:53:07.743 [0x7f0805a7b700] INFO - [I] CTVSStreamSource::Term. Streaming is stopped
Oct 28, 2019 16:53:07.743 [0x7f0805a7b700] INFO - [I] CTVSStreamSource::Term. Stream source is stopped
Oct 28, 2019 16:53:08.390 [0x7f07f57fa700] INFO - [I] transponder_streamer::idle_thread_func finished
Update: I rescanned channels and things are now working again. No idea what went wrong here…
