Livetv-dvr does not work
LiveTV does not work on my install, and has not worked for almost a year (was working previous to that.) I have a Hauppauge Dual tuner (legacy version.) Error is: Playback error, could not tune channel.)
What is needed to troubleshoot? Am a plexpass subscriber and this needs to work to justify.
thanks in advance,
A lot could have happened in a year, so I’ll go through some ideas. If nothing pops, server logs are needed that I’ve specified at the end.
  • Assuming that’s an OTA tuner, and sorry if Captain Obvious, but have you verified you can watch Live TV with your same antennae and cable connected directly to a TV? We could analyze Plex all day, but if something is up with the antennae or cable then we’re just going to beat our heads against the wall.
  • Since it has been so long since it has worked for you, what version of Plex Media Server are you using? (And platform - Win, Linux, etc?) Several months ago Plex changed their EPG provider, and old versions of the Plex Server software simply will no longer work for Live TV. IIRC you have to be on 1.16 or higher.
  • Again assuming your tuner is OTA. If so, have you gone into the Live TV and DVR section of Plex Server settings and rescanned channels? The FCC has mandated a channel “repacking” to free up frequencies, and many OTA channels either have or are in the process of moving frequencies. If you haven’t rescanned since channels have moved, then your tuner is looking for the channel(s) on the wrong broadcast frequency. That can cause it to not be able to tune a channel(s).
  • Assuming you are on a recent version (1.17 or 1.18), have you tried deleting the DVR and re-adding it? As part of the Plex EPG provider change many people needed to do this to get their Live TV/DVR working.
To troubleshoot more, Plex Server logs are going to be needed. First go into Plex web, then go into Settings -> General. Click on the “Show Advanced” button. Make sure “Enable Plex Media Server Debug Logging” is checked, and that “Enable Plex Media Server Verbose Logging” is UNchecked. To make it easiest to analyze, restart your Plex server and wait about 6 minutes for things to calm down. Then try to play a Live TV channel. Wait a couple minutes, then dowload logs from Plex web by going to Settings -> Troubleshooting and clicking the “Download Logs” button. A zip file will download.
Post it here.
Thanks for attempting to help.
Some answers:
-The OTA tuner tunes and streams perfectly inside the Hauppage viewing software and in my own code.
-Plex Media Server 1.18.0.1944- Windows
-Yes, have rescanned numerous times, including after re-adding the tuner.
-Yes, have deleted and re-added more times than I can count after previous 7 or 8 plex version upgrades hoping something would change.
I have a software engineering background, so can do more invasive testing if needed, but the stream from the unit itself is solid, as I’ve tapped into it in code successfully. The HD Homerun is also on the most recent 2017 I believe, firmware; its just an old unit I have had since back when I ran a Linux TV server on MythTV.
Log File Posting:
Oct 26, 2019 14:17:32.636 [1128] INFO - Plex Tuner Service v1.0.0.0 - Microsoft PC x64 - build:
Oct 26, 2019 14:17:32.636 [1128] INFO - Windows version: 6.1 (Build 7601), language en-US
Oct 26, 2019 14:17:32.636 [1128] INFO - 4 3467 MHz processor(s): Architecture=0, Level=6, Revision=15876 Processor Identifier=Intel64 Family 6 Model 62 Stepping 4, GenuineIntel
Oct 26, 2019 14:17:32.636 [1128] DEBUG - “C:\Program Files (x86)\Plex\Plex Media Server\Plex Tuner Service.exe” “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Private” “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Shared” 1.18.0.1944-f2cae8d6b 32600 /waitmutex
Oct 26, 2019 14:17:32.636 [2944] INFO - [I] broker_t::start…
Oct 26, 2019 14:17:32.652 [2944] INFO - [I] device_manager_t::init.
Oct 26, 2019 14:17:32.652 [2944] INFO - [I] device_manager_t::init. Initialize provider manager
Oct 26, 2019 14:17:32.652 [2944] INFO - [I] device_manager_t::init. Initialize all device auxes
Oct 26, 2019 14:17:32.652 [2944] INFO - [I] dvb_device_factory_t::get_aux_list
Oct 26, 2019 14:17:32.652 [2944] INFO - [I] bda_aux_t::init
Oct 26, 2019 14:17:32.839 [2944] INFO - [I] web_server_t::start. Starting web server on port 32600
Oct 26, 2019 14:17:41.001 [5060] INFO - [I] web_service_t::process_device_discovery
Oct 26, 2019 14:17:41.001 [5060] INFO - [I] device_reactor_t::get_device_list ()
Oct 26, 2019 14:17:41.001 [5060] INFO - [I] dvb_device_factory_t::get_device_list ()
Oct 26, 2019 14:17:43.079 [5060] INFO - [I] SAT2IP - discover_satip_servers(): no servers found
Oct 26, 2019 14:17:43.500 [5060] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#hdhr#0#269548663, Name HDHomeRun 1010FC77 (192.168.1.144) - 0, Standards 24
Oct 26, 2019 14:17:43.500 [5060] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#hdhr#1#269548663, Name HDHomeRun 1010FC77 (192.168.1.144) - 1, Standards 24
Oct 26, 2019 14:17:43.500 [2248] INFO - [I] DeviceGetListEx_impl: Filter [Silicondust HDHomeRun Tuner 1010FC77-0]
Oct 26, 2019 14:17:43.500 [2248] DEBUG - [I] BDA: DeviceGetListEx_impl. Skipped Silicondust virtual BDA driver
Oct 26, 2019 14:17:43.500 [2248] INFO - [I] DeviceGetListEx_impl: pDL->Count:0
Oct 26, 2019 14:17:43.500 [5060] DEBUG - [I] file_tuner::get_stream_file. File C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Private\devices\dvb\file\drv_file.ini does not exist
Oct 26, 2019 14:17:43.500 [5060] INFO - [I] device_manager_t::get_device_list. Device HDHomeRun 1010FC77 (192.168.1.144) - 0, id dvb#hdhr#0#269548663, tuners 1, state 0, standards 24
Oct 26, 2019 14:17:43.500 [5060] INFO - [I] device_manager_t::get_device_list. Device HDHomeRun 1010FC77 (192.168.1.144) - 1, id dvb#hdhr#1#269548663, tuners 1, state 0, standards 24
Oct 26, 2019 14:17:43.718 [5060] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:17:44.139 [5060] INFO - [I] web_service_t::process_get_scanners
Oct 26, 2019 14:17:44.763 [5060] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:17:45.185 [5060] INFO - [I] web_service_t::process_get_scanners
Oct 26, 2019 14:21:43.542 [5060] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:21:43.661 [6188] INFO - [I] web_service_t::process_start_channel (device dvb#hdhr#1#269548663, channel triplet://0:1485:3)
Oct 26, 2019 14:21:44.381 [6188] INFO - [I] device_manager_t::add_streamer. Channel triplet://0:1485:3, device dvb#hdhr#1#269548663, streamer id b6c8cd95-5f68-4699-b715-bf7fb0c74cdc
Oct 26, 2019 14:21:44.381 [6188] INFO - [I] device_reactor_t::create_device dvb#hdhr#1#269548663
Oct 26, 2019 14:21:44.381 [6188] INFO - [I] device_manager_t::add_streamer. Adding new streamer container for channel triplet://0:1485:3 on device device dvb#hdhr#1#269548663.
Oct 26, 2019 14:21:44.381 [6188] INFO - [I] transponder_streamer::start_idle_timer
Oct 26, 2019 14:21:44.381 [6188] INFO - [I] tvs_program_streamer::tvs_program_streamer. Select program for nid 0, tid 1485, sid 3
Oct 26, 2019 14:21:44.381 [5756] INFO - [I] streamer_container_t::control_thread. Added streamer b6c8cd95-5f68-4699-b715-bf7fb0c74cdc
Oct 26, 2019 14:21:44.381 [5756] INFO - [I] streamer_container_t::control_thread. First streamer was added. Start program streamer
Oct 26, 2019 14:21:44.381 [5756] INFO - [I] dvb_program_streamer_t::start. Starting program streamer for channel triplet://0:1485:3
Oct 26, 2019 14:21:44.381 [5756] INFO - [I] transponder_streamer::start_channel. Start request for channel triplet://0:1485:3
Oct 26, 2019 14:21:44.381 [5756] INFO - [I] transponder_streamer::stop_idle_timer
Oct 26, 2019 14:21:44.444 [2976] INFO - [I] hdhr_tuner_t::StartDevice. Starting device 269548663, frontend 1
Oct 26, 2019 14:21:44.444 [2976] INFO - [I] CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 41, modulation 0, polarization 0, symbol rate 0, LOF 0, LNB selection signal 0, FEC 0
Oct 26, 2019 14:21:44.444 [2976] INFO - [I] HDHR get_tuning_string: 8vsb:635028615
Oct 26, 2019 14:21:44.725 [2976] INFO - [I] hdhr_tuner_t::SetTuner. wait_for_lock status: 1, 31
Oct 26, 2019 14:21:44.865 [5756] INFO - [I] transponder_streamer::tune_transponder_impl. Signal stats: 28, 0, 0
Oct 26, 2019 14:21:44.865 [4900] INFO - [I] tvs_program_streamer::tuning_thread. Starting tuning thread for program triplet://0:1485:3
Oct 26, 2019 14:21:44.865 [4900] INFO - [I] tvs_program_streamer::SetPATScanState. Waiting for PAT…
Oct 26, 2019 14:21:44.881 [2384] INFO - [I] http_streamer_t::send_thread_func: adding http client
Oct 26, 2019 14:21:44.927 [2976] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 0, client triplet://0:1485:3
Oct 26, 2019 14:21:44.927 [2976] INFO - [I] HDHR add_pid. Adding pid 0
Oct 26, 2019 14:21:44.990 [2976] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 1, client triplet://0:1485:3
Oct 26, 2019 14:21:44.990 [2976] INFO - [I] HDHR add_pid. Adding pid 1
Oct 26, 2019 14:21:46.971 [6188] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:21:50.404 [6188] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:21:53.837 [6188] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:21:57.272 [6188] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:22:00.705 [6188] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:22:04.137 [6188] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:22:07.570 [6188] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:22:09.209 [6188] WARN - [E] http_streamer_t::handle_read: read_error: An existing connection was forcibly closed by the remote host (10054)
Oct 26, 2019 14:22:09.209 [6188] WARN - [E] http_streamer_t: http write error
Oct 26, 2019 14:22:09.209 [2384] INFO - [I] http_streamer_t::send_thread_func: removing http client
Oct 26, 2019 14:22:09.209 [2384] INFO - [I] http_streamer_t::send_thread_func: all clients are deleted. Setting exit flag
Oct 26, 2019 14:22:09.209 [6188] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:22:09.225 [5756] INFO - [I] streamer_container_t::control_thread. Removed disconnected streamer b6c8cd95-5f68-4699-b715-bf7fb0c74cdc
Oct 26, 2019 14:22:09.225 [5756] INFO - [I] streamer_container_t::delete_streamer. Last streamer was deleted. Stop program streamer
Oct 26, 2019 14:22:09.225 [5756] INFO - [I] dvb_program_streamer_t::stop. Stoping program streamer for channel triplet://0:1485:3
Oct 26, 2019 14:22:09.225 [5756] INFO - [I] transponder_streamer::stop_channel. Stop request for channel triplet://0:1485:3
Oct 26, 2019 14:22:09.271 [4900] INFO - [I] tvs_program_streamer::tuning_thread. Finished tuning thread for program triplet://0:1485:3
Oct 26, 2019 14:22:09.334 [2976] INFO - [I] CTVSStreamSource::RemoveAllPids. Removing PIDs for client triplet://0:1485:3
Oct 26, 2019 14:22:09.334 [2976] INFO - [I] HDHR delete_pid. Deleting pid 0
Oct 26, 2019 14:22:09.334 [2976] INFO - [I] HDHR delete_pid. Deleting pid 1
Oct 26, 2019 14:22:09.334 [5756] INFO - [I] transponder_streamer::start_idle_timer
Oct 26, 2019 14:22:11.113 [6024] INFO - [I] device_manager_t::idle_timer_func. Stream container for channel triplet://0:1485:3 on device dvb#hdhr#1#269548663 is idle. Deleting it.
Oct 26, 2019 14:22:13.765 [6776] INFO - [I] Stopping graph
Oct 26, 2019 14:22:14.186 [6024] INFO - [I] device_manager_t::idle_timer_func. Device dvb#hdhr#1#269548663 is idle. Unloading it.
Oct 26, 2019 14:22:14.186 [6024] INFO - [I] transponder_streamer::stop_idle_timer
Oct 26, 2019 14:22:14.186 [6024] INFO - [I] CTVSStreamSource::Term. Waiting for streaming thread to stop
Oct 26, 2019 14:22:14.249 [6024] INFO - [I] CTVSStreamSource::Term. Streaming is stopped
Oct 26, 2019 14:22:14.249 [6024] INFO - [I] CTVSStreamSource::Term. Stream source is stopped
Oct 26, 2019 14:22:14.904 [6776] INFO - [I] transponder_streamer::idle_thread_func finished
Oct 26, 2019 14:22:36.274 [4404] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:22:36.352 [5060] INFO - [I] web_service_t::process_start_channel (device dvb#hdhr#1#269548663, channel triplet://0:1481:3)
Oct 26, 2019 14:22:37.116 [5060] INFO - [I] device_manager_t::add_streamer. Channel triplet://0:1481:3, device dvb#hdhr#1#269548663, streamer id 23f7e679-cbbc-4a98-9740-23147b346cb0
Oct 26, 2019 14:22:37.116 [5060] INFO - [I] device_reactor_t::create_device dvb#hdhr#1#269548663
Oct 26, 2019 14:22:37.116 [5060] INFO - [I] device_manager_t::add_streamer. Adding new streamer container for channel triplet://0:1481:3 on device device dvb#hdhr#1#269548663.
Oct 26, 2019 14:22:37.116 [5060] INFO - [I] transponder_streamer::start_idle_timer
Oct 26, 2019 14:22:37.116 [5060] INFO - [I] tvs_program_streamer::tvs_program_streamer. Select program for nid 0, tid 1481, sid 3
Oct 26, 2019 14:22:37.116 [6240] INFO - [I] streamer_container_t::control_thread. Added streamer 23f7e679-cbbc-4a98-9740-23147b346cb0
Oct 26, 2019 14:22:37.116 [6240] INFO - [I] streamer_container_t::control_thread. First streamer was added. Start program streamer
Oct 26, 2019 14:22:37.116 [6240] INFO - [I] dvb_program_streamer_t::start. Starting program streamer for channel triplet://0:1481:3
Oct 26, 2019 14:22:37.116 [6240] INFO - [I] transponder_streamer::start_channel. Start request for channel triplet://0:1481:3
Oct 26, 2019 14:22:37.116 [6240] INFO - [I] transponder_streamer::stop_idle_timer
Oct 26, 2019 14:22:37.178 [6028] INFO - [I] hdhr_tuner_t::StartDevice. Starting device 269548663, frontend 1
Oct 26, 2019 14:22:37.178 [6028] INFO - [I] CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 7, modulation 0, polarization 0, symbol rate 0, LOF 0, LNB selection signal 0, FEC 0
Oct 26, 2019 14:22:37.178 [6028] INFO - [I] HDHR get_tuning_string: 8vsb:177028615
Oct 26, 2019 14:22:37.459 [6028] INFO - [I] hdhr_tuner_t::SetTuner. wait_for_lock status: 0, 0
Oct 26, 2019 14:22:37.600 [6240] INFO - [I] transponder_streamer::tune_transponder_impl. Signal stats: 13, 0, 0
Oct 26, 2019 14:22:37.600 [6844] INFO - [I] tvs_program_streamer::tuning_thread. Starting tuning thread for program triplet://0:1481:3
Oct 26, 2019 14:22:37.600 [6844] INFO - [I] tvs_program_streamer::SetPATScanState. Waiting for PAT…
Oct 26, 2019 14:22:37.615 [3460] INFO - [I] http_streamer_t::send_thread_func: adding http client
Oct 26, 2019 14:22:37.662 [6028] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 0, client triplet://0:1481:3
Oct 26, 2019 14:22:37.662 [6028] INFO - [I] HDHR add_pid. Adding pid 0
Oct 26, 2019 14:22:37.724 [6028] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 1, client triplet://0:1481:3
Oct 26, 2019 14:22:37.724 [6028] INFO - [I] HDHR add_pid. Adding pid 1
Oct 26, 2019 14:22:39.707 [5060] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:22:43.140 [5060] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:22:46.572 [4404] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:22:49.994 [4404] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:22:53.428 [4404] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:22:56.861 [5060] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:23:00.295 [5060] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:23:02.215 [6188] WARN - [E] http_streamer_t::handle_read: read_error: An existing connection was forcibly closed by the remote host (10054)
Oct 26, 2019 14:23:02.215 [6188] WARN - [E] http_streamer_t: http write error
Oct 26, 2019 14:23:02.215 [3460] INFO - [I] http_streamer_t::send_thread_func: removing http client
Oct 26, 2019 14:23:02.215 [3460] INFO - [I] http_streamer_t::send_thread_func: all clients are deleted. Setting exit flag
Oct 26, 2019 14:23:02.215 [5060] INFO - [I] web_service_t::process_device_status
Oct 26, 2019 14:23:02.262 [6240] INFO - [I] streamer_container_t::control_thread. Removed disconnected streamer 23f7e679-cbbc-4a98-9740-23147b346cb0
Oct 26, 2019 14:23:02.262 [6240] INFO - [I] streamer_container_t::delete_streamer. Last streamer was deleted. Stop program streamer
Oct 26, 2019 14:23:02.262 [6240] INFO - [I] dvb_program_streamer_t::stop. Stoping program streamer for channel triplet://0:1481:3
Oct 26, 2019 14:23:02.262 [6240] INFO - [I] transponder_streamer::stop_channel. Stop request for channel triplet://0:1481:3
Oct 26, 2019 14:23:02.308 [6844] INFO - [I] tvs_program_streamer::tuning_thread. Finished tuning thread for program triplet://0:1481:3
Oct 26, 2019 14:23:02.324 [6028] INFO - [I] CTVSStreamSource::RemoveAllPids. Removing PIDs for client triplet://0:1481:3
Oct 26, 2019 14:23:02.324 [6028] INFO - [I] HDHR delete_pid. Deleting pid 0
Oct 26, 2019 14:23:02.324 [6028] INFO - [I] HDHR delete_pid. Deleting pid 1
Oct 26, 2019 14:23:02.324 [6240] INFO - [I] transponder_streamer::start_idle_timer
Oct 26, 2019 14:23:03.915 [6024] INFO - [I] device_manager_t::idle_timer_func. Stream container for channel triplet://0:1481:3 on device dvb#hdhr#1#269548663 is idle. Deleting it.
Oct 26, 2019 14:23:07.567 [6164] INFO - [I] Stopping graph
Oct 26, 2019 14:23:10.032 [6024] INFO - [I] device_manager_t::idle_timer_func. Device dvb#hdhr#1#269548663 is idle. Unloading it.
Oct 26, 2019 14:23:10.032 [6024] INFO - [I] transponder_streamer::stop_idle_timer
Oct 26, 2019 14:23:10.032 [6024] INFO - [I] CTVSStreamSource::Term. Waiting for streaming thread to stop
Oct 26, 2019 14:23:10.048 [6024] INFO - [I] CTVSStreamSource::Term. Streaming is stopped
Oct 26, 2019 14:23:10.048 [6024] INFO - [I] CTVSStreamSource::Term. Stream source is stopped
Oct 26, 2019 14:23:10.812 [6164] INFO - [I] transponder_streamer::idle_thread_func finished
thanks for any input… above is 2 different attempts via 2 different browsers (Chrome then Mozilla)
A couple of things to try just for testing purposes: Try turning off hardware transcoding if you have it on. Also try it from a client that doesn’t require transcoding, such as PMP or the Plex app. Finally, try with only one of your two tuners configured just to see if you can get your Hauppage OR your HDHR working independently.
@sa2000 - Any thoughts on this? I’m seeing a number threads from previous versions with this “10054 connection forcibly closed” error, but the root causes ranged from something specific with the client to a problem with the probesize from the server.
‘Use hardware acceleration when available’ is off on the transcoder tab already, if this is the setting referred to.
And, I am only using one of the two tuners. I could try to configure the second tuner as a test, but I only have one input connected at the moment, so only configured one.
Whats odd, is this same hardware worked when the initial Live TV/DVR functionality was put in, and worked for a while before breaking about a year ago with a Plex update. Have not been able to get it working since… the Plex installation and hardware has not changed.
There is potentially value in trying it with the second tuner only. If it works then we know the problem is specific to Plex support of the first tuner…
I did find info on troubleshooting windows 10054 socket errors. I do think it is a good idea to also try playing Live TV from another client such as PMP or the Plex app.
I’m only seeing info level entries in the log you posted. Try turning on debug level logging in Plex Web -> Settings -> General. Check “Enable Plex Media Server Debug Logging”, but make sure verbose logging is not checked. Restart Plex, wait about 6 minutes for things to calm down, then try Live TV again and then download the logs. Most clients are able to produce logs as well, which could provide insight.
Is your server hardware and client hardware on wifi or wired? If on wifi, then try it on wired just to take out that variable since it does appear to be some type of connection issue.
Ok, sorry for delay there, am back:
I get same error on IOS Plex Apps on ipad, which i believe its direct. I also am on wired connection in the tests. Havent gotten around to initializing second tuner yet as I need to run another cable to do so.
Changed debug settings and opened a new Mozilla web client, here is the debug:
New log after changing debug:
Oct 30, 2019 18:17:32.151 [3760] INFO - Plex Tuner Service v1.0.0.0 - Microsoft PC x64 - build:
Oct 30, 2019 18:17:32.151 [3760] INFO - Windows version: 6.1 (Build 7601), language en-US
Oct 30, 2019 18:17:32.151 [3760] INFO - 4 3467 MHz processor(s): Architecture=0, Level=6, Revision=15876 Processor Identifier=Intel64 Family 6 Model 62 Stepping 4, GenuineIntel
Oct 30, 2019 18:17:32.151 [3760] DEBUG - “C:\Program Files (x86)\Plex\Plex Media Server\Plex Tuner Service.exe” “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Private” “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Shared” 1.18.1.1973-0f4abfbcc 32600 /waitmutex
Oct 30, 2019 18:17:32.151 [1156] INFO - [I] broker_t::start…
Oct 30, 2019 18:17:32.166 [1156] INFO - [I] device_manager_t::init.
Oct 30, 2019 18:17:32.166 [1156] INFO - [I] device_manager_t::init. Initialize provider manager
Oct 30, 2019 18:17:32.166 [1156] INFO - [I] device_manager_t::init. Initialize all device auxes
Oct 30, 2019 18:17:32.166 [1156] INFO - [I] dvb_device_factory_t::get_aux_list
Oct 30, 2019 18:17:32.166 [1156] INFO - [I] bda_aux_t::init
Oct 30, 2019 18:17:32.353 [1156] INFO - [I] web_server_t::start. Starting web server on port 32600
Oct 30, 2019 18:17:40.466 [0716] INFO - [I] web_service_t::process_device_discovery
Oct 30, 2019 18:17:40.466 [0716] INFO - [I] device_reactor_t::get_device_list ()
Oct 30, 2019 18:17:40.466 [0716] INFO - [I] dvb_device_factory_t::get_device_list ()
Oct 30, 2019 18:17:42.541 [0716] INFO - [I] SAT2IP - discover_satip_servers(): no servers found
Oct 30, 2019 18:17:42.963 [0716] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#hdhr#0#269548663, Name HDHomeRun 1010FC77 (192.168.1.144) - 0, Standards 24
Oct 30, 2019 18:17:42.963 [0716] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#hdhr#1#269548663, Name HDHomeRun 1010FC77 (192.168.1.144) - 1, Standards 24
Oct 30, 2019 18:17:42.963 [3764] INFO - [I] DeviceGetListEx_impl: Filter [Silicondust HDHomeRun Tuner 1010FC77-0]
Oct 30, 2019 18:17:42.963 [3764] DEBUG - [I] BDA: DeviceGetListEx_impl. Skipped Silicondust virtual BDA driver
Oct 30, 2019 18:17:42.963 [3764] INFO - [I] DeviceGetListEx_impl: pDL->Count:0
Oct 30, 2019 18:17:42.963 [0716] DEBUG - [I] file_tuner::get_stream_file. File C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Private\devices\dvb\file\drv_file.ini does not exist
Oct 30, 2019 18:17:42.963 [0716] INFO - [I] device_manager_t::get_device_list. Device HDHomeRun 1010FC77 (192.168.1.144) - 0, id dvb#hdhr#0#269548663, tuners 1, state 0, standards 24
Oct 30, 2019 18:17:42.963 [0716] INFO - [I] device_manager_t::get_device_list. Device HDHomeRun 1010FC77 (192.168.1.144) - 1, id dvb#hdhr#1#269548663, tuners 1, state 0, standards 24
Oct 30, 2019 18:17:43.182 [0716] INFO - [I] web_service_t::process_device_status
Oct 30, 2019 18:17:43.603 [0716] INFO - [I] web_service_t::process_get_scanners
Oct 30, 2019 18:17:44.243 [2100] INFO - [I] web_service_t::process_device_status
Oct 30, 2019 18:17:44.664 [0716] INFO - [I] web_service_t::process_get_scanners
Oct 30, 2019 18:41:35.129 [0716] INFO - [I] web_service_t::process_device_status
Oct 30, 2019 18:41:35.238 [3400] INFO - [I] web_service_t::process_start_channel (device dvb#hdhr#1#269548663, channel triplet://0:1485:3)
Oct 30, 2019 18:41:35.971 [3400] INFO - [I] web_service_t::process_start_channel. Trying start channel triplet://0:1485:3 on device dvb#hdhr#1#269548663 (idx 0 out of 1 available)
Oct 30, 2019 18:41:35.971 [3400] INFO - [I] device_manager_t::add_streamer. Channel triplet://0:1485:3, device dvb#hdhr#1#269548663, streamer id 031417bc-8cb4-4d4a-b282-1323e3f9a911
Oct 30, 2019 18:41:35.971 [3400] INFO - [I] device_reactor_t::create_device dvb#hdhr#1#269548663
Oct 30, 2019 18:41:35.971 [3400] INFO - [I] device_manager_t::add_streamer. Adding new streamer container for channel triplet://0:1485:3 on device device dvb#hdhr#1#269548663.
Oct 30, 2019 18:41:35.971 [3400] INFO - [I] transponder_streamer::start_idle_timer
Oct 30, 2019 18:41:35.971 [3400] INFO - [I] tvs_program_streamer::tvs_program_streamer. Select program for nid 0, tid 1485, sid 3
Oct 30, 2019 18:41:35.971 [0624] INFO - [I] streamer_container_t::control_thread. Added streamer 031417bc-8cb4-4d4a-b282-1323e3f9a911
Oct 30, 2019 18:41:35.971 [0624] INFO - [I] streamer_container_t::control_thread. First streamer was added. Start program streamer
Oct 30, 2019 18:41:35.971 [0624] INFO - [I] dvb_program_streamer_t::start. Starting program streamer for channel triplet://0:1485:3
Oct 30, 2019 18:41:35.971 [0624] INFO - [I] transponder_streamer::start_channel. Start request for channel triplet://0:1485:3
Oct 30, 2019 18:41:35.971 [0624] INFO - [I] transponder_streamer::stop_idle_timer
Oct 30, 2019 18:41:36.033 [2832] INFO - [I] hdhr_tuner_t::StartDevice. Starting device 269548663, frontend 1
Oct 30, 2019 18:41:36.033 [2832] INFO - [I] CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 41, modulation 0, polarization 0, symbol rate 0, LOF 0, LNB selection signal 0, FEC 0
Oct 30, 2019 18:41:36.033 [2832] INFO - [I] HDHR get_tuning_string: 8vsb:635028615
Oct 30, 2019 18:41:36.314 [2832] INFO - [I] hdhr_tuner_t::SetTuner. wait_for_lock status: 1, 36
Oct 30, 2019 18:41:36.455 [0624] INFO - [I] transponder_streamer::tune_transponder_impl. Signal stats: 24, 0, 0
Oct 30, 2019 18:41:36.455 [3400] INFO - [I] web_service_t::process_start_channel. Successfully started channel triplet://0:1485:3 on device dvb#hdhr#1#269548663
Oct 30, 2019 18:41:36.455 [7076] INFO - [I] tvs_program_streamer::tuning_thread. Starting tuning thread for program triplet://0:1485:3
Oct 30, 2019 18:41:36.455 [7076] INFO - [I] tvs_program_streamer::SetPATScanState. Waiting for PAT…
Oct 30, 2019 18:41:36.470 [4860] INFO - [I] http_streamer_t::send_thread_func: adding http client
Oct 30, 2019 18:41:36.517 [2832] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 0, client triplet://0:1485:3
Oct 30, 2019 18:41:36.517 [2832] INFO - [I] HDHR add_pid. Adding pid 0
Oct 30, 2019 18:41:36.579 [2832] INFO - [I] CTVSStreamSource::AddPID. Requesting PID 1, client triplet://0:1485:3
Oct 30, 2019 18:41:36.579 [2832] INFO - [I] HDHR add_pid. Adding pid 1
Oct 30, 2019 18:41:38.561 [3400] INFO - [I] web_service_t::process_device_status
Oct 30, 2019 18:41:41.994 [3400] INFO - [I] web_service_t::process_device_status
Oct 30, 2019 18:41:45.427 [3400] INFO - [I] web_service_t::process_device_status
Oct 30, 2019 18:41:48.860 [3400] INFO - [I] web_service_t::process_device_status
Oct 30, 2019 18:41:52.293 [3400] INFO - [I] web_service_t::process_device_status
Oct 30, 2019 18:41:55.741 [2100] INFO - [I] web_service_t::process_device_status
Oct 30, 2019 18:41:59.174 [3400] INFO - [I] web_service_t::process_device_status
Oct 30, 2019 18:42:01.077 [3400] WARN - [E] http_streamer_t::handle_read: read_error: An existing connection was forcibly closed by the remote host (10054)
Oct 30, 2019 18:42:01.077 [3400] WARN - [E] http_streamer_t: http write error
Oct 30, 2019 18:42:01.077 [4860] INFO - [I] http_streamer_t::send_thread_func: removing http client
Oct 30, 2019 18:42:01.077 [4860] INFO - [I] http_streamer_t::send_thread_func: all clients are deleted. Setting exit flag
Oct 30, 2019 18:42:01.077 [3400] INFO - [I] web_service_t::process_device_status
Oct 30, 2019 18:42:01.124 [0624] INFO - [I] streamer_container_t::control_thread. Removed disconnected streamer 031417bc-8cb4-4d4a-b282-1323e3f9a911
Oct 30, 2019 18:42:01.124 [0624] INFO - [I] streamer_container_t::delete_streamer. Last streamer was deleted. Stop program streamer
Oct 30, 2019 18:42:01.124 [0624] INFO - [I] dvb_program_streamer_t::stop. Stoping program streamer for channel triplet://0:1485:3
Oct 30, 2019 18:42:01.124 [0624] INFO - [I] transponder_streamer::stop_channel. Stop request for channel triplet://0:1485:3
Oct 30, 2019 18:42:01.140 [7076] INFO - [I] tvs_program_streamer::tuning_thread. Finished tuning thread for program triplet://0:1485:3
Oct 30, 2019 18:42:01.202 [2832] INFO - [I] CTVSStreamSource::RemoveAllPids. Removing PIDs for client triplet://0:1485:3
Oct 30, 2019 18:42:01.202 [2832] INFO - [I] HDHR delete_pid. Deleting pid 0
Oct 30, 2019 18:42:01.202 [2832] INFO - [I] HDHR delete_pid. Deleting pid 1
Oct 30, 2019 18:42:01.202 [0624] INFO - [I] transponder_streamer::start_idle_timer
Oct 30, 2019 18:42:02.715 [3580] INFO - [I] device_manager_t::idle_timer_func. Stream container for channel triplet://0:1485:3 on device dvb#hdhr#1#269548663 is idle. Deleting it.
Oct 30, 2019 18:42:06.414 [6732] INFO - [I] Stopping graph
Oct 30, 2019 18:42:08.800 [3580] INFO - [I] device_manager_t::idle_timer_func. Device dvb#hdhr#1#269548663 is idle. Unloading it.
Oct 30, 2019 18:42:08.800 [3580] INFO - [I] transponder_streamer::stop_idle_timer
Oct 30, 2019 18:42:08.800 [3580] INFO - [I] CTVSStreamSource::Term. Waiting for streaming thread to stop
Oct 30, 2019 18:42:08.863 [3580] INFO - [I] CTVSStreamSource::Term. Streaming is stopped
Oct 30, 2019 18:42:08.863 [3580] INFO - [I] CTVSStreamSource::Term. Stream source is stopped
Oct 30, 2019 18:42:09.627 [6732] INFO - [I] transponder_streamer::idle_thread_func finished
Where are the mozilla web client logs located you speak of?
thanks,
