Live TV HD channels constantly stuttering
Server Version#: Plex for Windows 1.26.0.5715
Player Version#: Plex for Windows 1.44.0
Tuner Make/Model: Hauppauge WinTV-quadHD
Guide/Lineup name: Local Broadcast Listings
Using XMLTV?: No
Channel number/Name: All HD Channels
Hi there guys!
Just as the title says, I am unable to see any Live TV channels from my clients since the video and audio will keep suttering every second.
The same channels in SD quality work fine.
I have also tested by using WinTV 8.5 to rule out any issue with the TV signal getting into the tuner, they are working absolutely fine…
My server specs are as follows:
Intel Xeon 1290v2
32Gb RAM
Transcoding folder configured in RAMDisk (16Gb)
Worth mentioning all usage is done remotely, but I should have enough bandwidth to stream (100/100Mb) and I am not transcoding any content.
This is driving me mad since in theory it should work and it is just annoying needing to see channels in SD when HD is available.
Any thoughts guys?
Thank you for reading!
