Live TV Integration
Hey All,
Love the new free Live TV channels. Could you guys look at integrating the Live TV&DVR menu item with the new Live TV channels. It looks a bit confusing on the side menu section having the two entries. All under the one menu item would be great…
Another wish is to be able to be able to add multiple XML files to LiveTV&DVR tuners. At the moment you can only add one. Would be great to be able to add the XML file per tuner.
Dont wanna hijack, but maybe m3u files for iptv as well?
Yeah, I wouldn’t mind m3u files as well, although if they add the build your own channel stuff that would be pretty good as well.
I think the Live TV & DVR section might need a bit of a rework to merge it all together and be able to have multiple sources for live channels, External Tuner, Plex Live Channels, IPTV, and User defined Channels. Would be a pretty nice bit of gear if that happens.
