Live TV not working, Plex V 1.43.1.10611
Server Version#: 1.43.1.10611
Player Version#: 1.43.1.10611
Tuner Make/Model: HDHomeRun CONNECT QUATRO
Guide/Lineup name: Local Broadcast Listings (90 channels)
Using XMLTV?:
Channel number/Name: All
Live TV stopped working on MacOS Plex Server months ago, using HDHomeRun. As requested, providing Server Logs. Thank you.
@jpack0 I still see hw decode in your logs
I’ve turned it off everywhere I can find it… where am I missing it?
did you disable settings->transcoder->use hardware acceleration when available?
I have it turned off there, and in the Tuner Settings. Didn’t seem to make a change.
can you enable that setting, disable use hw encoding, then re-disable that setting?
:slight_smile: I was just returning to write; I turned it on again and then back off. Restarted the server a couple times, and now I am finally able to see live tv again! After months of being out. :rofl: Thanks @chris_decker08 … I hope this holds out for a while!
