Tuner Make/Model: Vbox 4134 DVB-s2
Guide/Lineup name: Freesat (122 channels)
Using XMLTV?: Using the guide mapped on the Plex interface
Channel number/Name: Most Channels do not stream to Plex but playback natively on VBox HDMI
Everything looks OK. It used to work fine and I’ve always had the server running on my M1 Mac mini but now I get the following error when trying to play back/stream most of the channels:
Playback Error
Could not tune channel. Please check your tuner or antenna.
The Vbox plays back the channels no problem when playing direct from the Vbox itself via HDMI
Some channels stream ok on Plex Live TV, but only 2 or 3 of the channels E.G. Channel 4 HD and BBC Two HD stream perfectly well.
Please provide actual versions. “Latest” means different things depending on whether or not you’re follow the stable channel or beta. And different players (clients) have different versions available.
The web app is a player, and it has its own version. You can see it by browsing to Settings → [Plex Web] → General. It will differ based upon how you’re accessing it (local IP vs app.plex.tv).
Well dang. Sorry, I’m out of ideas, other than to perhaps provide your server logs (debug enabled, verbose disabled) of a failed live TV streaming session. You can click that orange link to see how to collect the logs.
My initial assumption was that it’s a transcoder failure, but you’re on the stable server version (the beta has some known issues).
Here I can only test with an M2 MacBook Air using an HDHomeRun Flex 4K tuner. This environment requires that the above setting be disabled which is why I suggested that. In your region, with that tuner, you may have different issues.
its weird that I can only find 2 channels that are working and I have two tuners on the Vbox. Im going to restart it. I really have no idea why this is happening
