This has been happening for at least a week (as my shows have not been recording). I have tried deleting the DVR and setting up again. Did not resolve the issue.
Server Version#: 1.32.1.6983
Player Version#: 4.104.2
Tuner Make/Model: HDHomeRun Connect Duo
Guide/Lineup name: Local Broadcast Listings (120 channels)
Using XMLTV?: No
Channel number/Name: All
It could be an issue with EPG data for the specific ZIP code you’ve selected. You may want to delete the DVR again, and then recreate it using a different, nearby ZIP code to see if you experience the same with different guide data. I’d try several, if possible.
It could also be a client issue. If you haven’t already, try one or more different clients.
This has also been happening to me as I set up my Plex server on a synology NAS with an Android client (Nvidia Shield). It doesn’t seem to matter what zip code around me that I use. I’m certainly not going to “go premium” if I can’t even get an EPG that works. There is a surprising lack of information on how to resolve this on the Internet.
Non Plex Pass users only get 3 hours in the epg so a manual refresh is required beforehand.
