LiveTV changes Channel during recording
Server Version#: 1.40.4.8679
Player Version#: 4.132.2
Tuner Make/Model: VBox TV Gateway for Terrestrial – DVB-T/T2 XTi 3442
Guide/Lineup name:
Using XMLTV?: no (I think)
Channel number/Name: reproduced on TF1 and France2
Hi
Since few months I encountered problems with my recordings: the recording starts correctly and after some time, it switches channel continuing recording.
The video is consequently useless because I miss the end :frowning:
I did not upgrade my VBox (no update available).
I’ve been using the VBox since february 2024 and it worked until June 2024.
My recordings parameters are :
  • resolution: prefer HD
  • Replace lower resolution items : false
  • MINUTES BEFORE START : 0
  • MINUTES AFTER END: 30
  • POSTPROCESSING SCRIPT : nothing
  • DETECT COMMERCIALS: detect commercials and mark for skip
  • Perform refresh of program guide data.: true
TY
Tang
Hi
I tried to record something yesterday and it has recorded only 9 mins… while it should last at least 2 hours.
I forced channel during recording settings to avoid channel jump during recording.
I don’t know what to do to fix that. Is it a server side issue ?
Tang
Hi
Here some logs of last recording (yesterday)
As usually recording does not work: switch from channel after 17 minutes, and last ~1h instead of ~2h.
As we can see quickly in logs, recording activity stoped suddenly after ~1h passing from 34% of completion to 100% unexpectedly :frowning:
But I found nothing about channel switch
I can provide full log if necessary
Line 6121: Aug 27, 2024 21:10:00.028 [139797657389880] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: registered new activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - Recording
Line 7455: Aug 27, 2024 21:11:45.058 [139797635353400] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 1.0% - Recording
Line 8544: Aug 27, 2024 21:13:33.437 [139797638466360] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 2.0% - Recording
Line 9594: Aug 27, 2024 21:15:17.511 [139797632723768] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 3.0% - Recording
Line 10652: Aug 27, 2024 21:17:02.479 [139797638466360] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 4.0% - Recording
Line 11699: Aug 27, 2024 21:18:46.795 [139797635353400] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 5.0% - Recording
Line 12734: Aug 27, 2024 21:20:30.956 [139797666798392] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 6.0% - Recording
Line 13790: Aug 27, 2024 21:22:15.468 [139797666798392] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 7.0% - Recording
Line 14943: Aug 27, 2024 21:24:00.384 [139797626231608] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 8.0% - Recording
Line 15994: Aug 27, 2024 21:25:45.353 [139797638466360] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 9.0% - Recording
Line 17099: Aug 27, 2024 21:27:33.449 [139797657389880] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 10.0% - Recording
Line 18126: Aug 27, 2024 21:29:17.532 [139797630614328] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 11.0% - Recording
Line 19188: Aug 27, 2024 21:31:01.665 [139797666798392] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 12.0% - Recording
Line 20247: Aug 27, 2024 21:32:45.534 [139797638466360] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 13.0% - Recording
Line 21318: Aug 27, 2024 21:34:33.250 [139797632723768] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 14.0% - Recording
Line 22362: Aug 27, 2024 21:36:17.646 [139797632723768] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 15.0% - Recording
Line 23427: Aug 27, 2024 21:38:01.818 [139797626231608] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 16.0% - Recording
Line 24472: Aug 27, 2024 21:39:45.900 [139797666798392] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 17.0% - Recording
Line 25492: Aug 27, 2024 21:41:30.106 [139797638466360] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 18.0% - Recording
Line 26551: Aug 27, 2024 21:43:17.465 [139797666798392] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 19.0% - Recording
Line 27629: Aug 27, 2024 21:45:02.321 [139797638466360] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 20.0% - Recording
Line 28694: Aug 27, 2024 21:46:46.872 [139797626231608] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 21.0% - Recording
Line 29729: Aug 27, 2024 21:48:30.671 [139797638466360] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 22.0% - Recording
Line 30762: Aug 27, 2024 21:50:15.059 [139797638466360] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 23.0% - Recording
Line 31871: Aug 27, 2024 21:52:03.093 [139797626231608] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 24.0% - Recording
Line 34183: Aug 27, 2024 21:53:47.320 [139797632723768] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 25.0% - Recording
Line 35461: Aug 27, 2024 21:55:32.075 [139797615684408] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 26.0% - Recording
Line 36899: Aug 27, 2024 21:57:16.595 [139797613574968] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 27.0% - Recording
Line 38144: Aug 27, 2024 21:59:01.622 [139797657389880] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 28.0% - Recording
Line 39345: Aug 27, 2024 22:00:46.230 [139797622176568] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 29.0% - Recording
Line 40566: Aug 27, 2024 22:02:30.982 [139797638466360] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 30.0% - Recording
Line 41753: Aug 27, 2024 22:04:15.441 [139797674535736] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 31.0% - Recording
Line 42963: Aug 27, 2024 22:06:00.046 [139797622176568] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 32.0% - Recording
Line 44240: Aug 27, 2024 22:07:48.156 [139797613738808] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 33.0% - Recording
Line 45484: Aug 27, 2024 22:09:33.103 [139797630614328] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 34.0% - Recording
Line 45570: Aug 27, 2024 22:09:51.216 [139797668907832] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 100.0% - Recording
Line 45571: Aug 27, 2024 22:09:51.216 [139797668907832] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: updated activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c - completed 100.0% - Recording
Line 45771: Aug 27, 2024 22:09:53.130 [139797668907832] DEBUG - [Grabber/87f154c9e3ce6428fb7e789ae143e5443c8378db] Activity: Ended activity 7b9c9704-8dcb-4c0d-8e47-e0e74fb3248c.
After some other investigations it seems it came from Vbox hardware. After a full reboot of device, the problem disappeared.
