Is there any way to have Plex pull episode descriptions from agents, ect, but generate it’s own thumbnails? A few TV shows on our server have thumbnails containing station watermarks and/or are low quality.
Your PMS does generate it’s own thumbnails from the file itself, but it’s not possible to set this to override the image from the agent. You have to do it manually. If you look at editing the poster or background, you will see the one taken from the file as options at the end.
