Long Movies Not Playing On TV
Server Version#:
So far I have noticed with three movies, Avatar Way of the Water, Guardians Vol 3, and John Wick 4, I try to watch on my TV through my Roku and it gives me the following error. I did see an older post about going into the preferences, but my Roku is new (within the last 6 months) and I don’t have the same menu options.
How do I play these longer movies on my Roku?
Just checking to see if anyone else is having this issue.
I contacted Roku and apparently I am not the only one with this issue. They gave me steps to uninstall the app and reinstall it. They had me hard wire to ensure a strong connection (which I already do), they asked me to plug and unplug. Nothing worked. The other person said the same thing.
Roku’s response was to contact Plex because it wasn’t on their end.
We would likely need to see the roku logs. I can’t find the other topic you mentioned with similar issue at the moment if you can give a link I might remember if the solution is still relevant in current versions of app
