Looking for new Roku/TV remote
My dog destroyed both the TV remote and the Roku remote. Both had to be thrown out. I’m looking for a new remote that has functions for both, such as this one, but all those use the learning method, meaning I need the original remote to program them. And as I said, I threw it out. Any suggestions on what I can get?
https://www.amazon.com/s?k=roku+remote
I simply have to believe there is a remote that will work for you above - unless you live in China (then it should be fairly easy to bend over and pick one up off the ground).
I found this, which might work.
EDIT: Bought it, works well
eBay is a good source, great search parameters.
