Loop selected videos
We are a video production company and we are looking into using Plex as a way of exhibiting our work at various business exhibitions. We started by just creating a dvd which was easily loopable and playable in a dvd player - but this was limited to standard definition. Earlier this year we moved to Apples Frontrow as a way of selecting videos and playing them back all in 1080p which is what 99% of our work is filmed in. The only problem with Frontrow is there is no way of selecting a video to play which just loops until you select another instead on constantly holding the Apple Remote and pressing play every 2 minutes at the end of a video which after 5 hours of exhibiting and standing on your feet gets a bit tiring.
Is there any feature that is already in / or can easily be added to flex to loop videos? So far it looks very customisable so we can add our logos in background images etc but the ability to loop would be great. Any advice would be appreciated.
Regards
James
PS: I have already gone down the method of just copying and pasting a video sequence multiple times in our video editing software to make the video appear looping but this is a messy way round a problem and not only takes a very very very long time to render, but also means that at some point you will get to the end of a video.
Have they seriously never responded to your question? I’m offended, and will find the solution. Mark my words.
