Losing Ethernet Connection after PlexConnect install
tried to run the scripts again, but when it gets to cd/Applications/PlexConnect, it starts telling me that no such file or directory. I must have the folder in the wrong place. I put the folder in the Applications folder (SFTP) along with the AppleTV and
here is the terminal output once I enter your commands:
Apple-TV:~ root# dpkg -i python........
dpkg: error processing python........ (--install):
 cannot access archive: No such file or directory
Errors were encountered while processing:
 python........
Apple-TV:~ root# apt-get -f install
Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 16 not upgraded.
Apple-TV:~ root# apt-get update
Get:1 http://apt.saurik.com ios/793.00 Release.gpg [189B]
Hit http://dl.firecore.com  Release.gpg
Hit http://apt.saurik.com ios/793.00 Release
Hit http://apt.modmyi.com stable Release.gpg
Ign http://mirrors.xbmc.org ./ Release.gpg
Hit http://cydia.zodttd.com stable Release.gpg
Get:2 http://apt.thebigboss.org stable Release.gpg [198B]
Hit http://apt.saurik.com ios/793.00/main Packages/DiffIndex
Hit http://apt.awkwardtv.org stable Release.gpg
Hit http://apt.thebigboss.org stable Release
Hit http://apt.modmyi.com stable/main Packages/DiffIndex
Hit http://cydia.zodttd.com stable/main Packages/DiffIndex
Ign http://dl.firecore.com  Packages/DiffIndex
Ign http://mirrors.xbmc.org ./ Packages/DiffIndex
Hit http://dl.firecore.com  Packages
Hit http://apt.thebigboss.org stable/main Packages/DiffIndex
Hit http://mirrors.xbmc.org ./ Packages
Hit http://apt.awkwardtv.org stable/main Packages/DiffIndex
Fetched 387B in 3s (123B/s)
Apple-TV:~ root# apt-get upgrade
The following packages will be upgraded:
  apt7-lib berkeleydb com.saurik.substrate.safemode coreutils coreutils-bin
  curl gzip mobilesubstrate ncurses openssh openssl pcre sqlite3-lib unzip
  wget zip
16 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 5286kB of archives.
After this operation, 1782kB of additional disk space will be used.
Do you want to continue [Y/n]? cd /Applications/PlexConnect
chmod +x PlexConnect.py
chmod +x PlexConnect_daemon.py
cd support
cd OSX
chmod +x PlexConnect.bash
chmod +x createcert.bash
chmod +x install.bash
chmod +x restart.bash
chmod +x uninstall.bash
./install.bash
cd ..
cd aTV_jailbreak
chmod +x install_button.bash
./install_button.bashAbort.
Apple-TV:~ root# chmod +x PlexConnect.py
chmod: cannot access `PlexConnect.py': No such file or directory
Apple-TV:~ root# chmod +x PlexConnect_daemon.py
chmod: cannot access `PlexConnect_daemon.py': No such file or directory
Apple-TV:~ root# cd support
-sh: cd: support: No such file or directory
Apple-TV:~ root# cd OSX
-sh: cd: OSX: No such file or directory
Apple-TV:~ root# chmod +x PlexConnect.bash
chmod: cannot access `PlexConnect.bash': No such file or directory
Apple-TV:~ root# chmod +x createcert.bash
chmod: cannot access `createcert.bash': No such file or directory
Apple-TV:~ root# chmod +x install.bash
chmod: cannot access `install.bash': No such file or directory
Apple-TV:~ root# chmod +x restart.bash
chmod: cannot access `restart.bash': No such file or directory
Apple-TV:~ root# chmod +x uninstall.bash
chmod: cannot access `uninstall.bash': No such file or directory
Apple-TV:~ root# ./install.bash
-sh: ./install.bash: No such file or directory
Apple-TV:~ root# cd ..
Apple-TV:/var root# cd aTV_jailbreak
-sh: cd: aTV_jailbreak: No such file or directory
Apple-TV:/var root# chmod +x install_button.bash
chmod: cannot access `install_button.bash': No such file or directory
Apple-TV:/var root# ./install_button.bash
>>ran install cydia and install python and both say "newest version"
cydia doesn't know about python 2.7.x. It *thinks* 2.5.x is the current version. At least, that what happened when I worked on those scripts.
SSH into you aTV, type "python" and check if it says 2.5.something. If so, update *manually* to 2.7.3.
Okay... post #127. I am done. :-D
Apple-TV:~ root# python
Python 2.7.3 (default, Aug 11 2012, 10:54:38)
[GCC 4.2.1 Compatible Apple Clang 3.0 (tags/Apple/clang-211.11)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
Looks promising. :-)
Progress: got the PlexConnect Icon to pop up on the aTV, but gives me a 404 error
ok I seen this before. Post your settings.cfg & hosts file. Also your dns should be set to auto.
hosts.zip <-----use this
This is my working settings.cfg, the other one works as well this is just what I use.
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
enable_dnsserver = False
logpath = .
ip_pms = 127.0.0.1
enable_plexgdm = False
hosttointercept = localhost
port_ssl = 443
enable_webserver_ssl = False
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = False
And my working hosts (unzip the file before you use it in place of yours):
# Host Database
# localhost is used to configure the loopback interface
# when the system is booting.  Do not change this entry.
127.0.0.1 localhost
255.255.255.255 broadcasthost
::1             localhost
fe80::1%lo0 localhost
127.0.0.1 mesu.apple.com
127.0.0.1 appldnld.apple.com
127.0.0.1 appldnld.apple.com.edgesuite.net
Set DNS to auto and you should be up and running (I hope) :D
settings.cfg
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.178.10
port_pms = 32400
port_dnsserver = 53
ip_plexconnect = 127.0.0.1
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
loglevel = Normal
logpath = .
host - replaced with the one you just posted
# Host Database
127.0.0.1 localhost
::1             localhost
settings.cfg
[PlexConnect]
port_pms = 32400
port_dnsserver = 53
port_webserver = 80
port_ssl = 443
loglevel = Normal
logpath = .
USE THIS ONE BELOW!
[PlexConnect]
port_pms = 32400
port_webserver = 80
loglevel = Normal
logpath = .
ip_pms = 127.0.0.1
port_ssl = 443
port_dnsserver = 53
Make them match ;)
More Progress! Now, I get into PlexConnect, but it Discovery says 0 servers found. Also, it says "failed" when I try to log in with myPlex.
Strangly my account got locked. Needless to say, I got it unlocked and all is working perfectly now! You guys really helped me out! How can I show my appreciation?
https://forums.plex.tv/topic/80675-donations-donations/ :smiley:
Will do!
The addsite solution has been working like a champ. I absolutely love the simplicity! I have run into a small hiccup.
Every 3 or 4 days I get the error in PlexConnect that it cannot connect to the server. If I go to Plex/Web, my settings icon has an "!". Once I go to MyPlex in Plex Media Server, I see that the server is disconnected. It is quite simple to click the reconnect and it states that it is mapped to port xxxxx. Is there any way to keep this from disconnecting?
PMS Version 0.9.9.5.411-da1d892
OSX 10.8.5
OSX 10.8.5
This looks like more of a PMS error, are you using UPNP or manually opening port 32400 for MyPlex?
I do not have the manually open port 32400 option checked in the setting so I assume UPNP
UPNP or manually opening the port is done on your router. It looks like a PMS issue though (or a network issue affecting your PMS MyPlex connectivity). Do you have require authentication on local networks checked?
No I dont
I am using airport utility with my time capsule as well
On your time capsule do you have anything set up as the “default host” entry?
