I tried several things since I know about systems, and stuff like that,
first I notice that my CMD window was not comunicating with my ATV all I was seeing was this
Oct 14,2018 01:26:05 PlexConnect: ***
Oct 14,2018 01:26:05 PlexConnect: PlexConnect
Oct 14,2018 01:26:05 PlexConnect: Press CTRL-C to shut down.
Oct 14,2018 01:26:05 PlexConnect: Started
Oct 14,2018 01:26:05 PlexConnect: Version: 0.5-dev-161017
Oct 14,2018 01:26:05 PlexConnect: Python: 2.7.14 (v2.7.14:84471935ed, Sep 16 2017, 20:19:30) [MSC v.1500 32 bit (Intel)]
Oct 14,2018 01:26:05 PlexConnect: Host OS: win32
Oct 14,2018 01:26:05 PlexConnect: PILBackgrounds: Is PIL installed? False
Oct 14,2018 01:26:05 PlexConnect: IP_self: xxx.xxx.x.xxx
Oct 14,2018 01:26:05 DNSServer: Started
Oct 14,2018 01:26:05 DNSServer: ***
Oct 14,2018 01:26:05 DNSServer: DNSServer: Serving DNS on xxx.xxx.x.xxx port 53.
Oct 14,2018 01:26:05 DNSServer: intercept: ['trailers.apple.com'] => xxx.xxx.x.xxx
Oct 14,2018 01:26:05 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
Oct 14,2018 01:26:05 DNSServer: forward other to higher level DNS: 8.8.8.8
Oct 14,2018 01:26:05 WebServer: Started
Oct 14,2018 01:26:05 WebServer: ***
Oct 14,2018 01:26:05 WebServer: WebServer: Serving HTTP on xxx.xxx.x.xxx port 80.
Oct 14,2018 01:26:06 WebServer: ***
Oct 14,2018 01:26:06 WebServer: WebServer: Serving HTTPS on xxx.xxx.x.xxx port 443.
Long story short. My DNS was set to Manual, with my IP Address, (as it should) I have not updated ANYTHING since I Installed PlexConnect (Except my PMS which I always have been updating with no further problems)
Looking deeper, I noticed that the “Trailers Profile” was missing, I was trying to Reinstall the Certificate(http://trailers.apple.com/trailers.cer) but I was getting the Error 109 every single attempt.
I Restored my ATV to Factory Settings, and did everithing again. with same results. I even tried to put my IP Address instead of trailers.apple.com (example http://123.456.0.xxx/trailers.cer)but it keeps loading with no results.
Now I have Deleted Python and PlexConnect-master folder, and I did a “fresh” Install.
As you can see I was previously Running Python 2.7.14 and PlexConnect 0.5-dev-161017
Now Im facing another Problem, I Installed Python 2.7 and PlexConnect v0.5 and Every time I run Plexconnect.py the CMD window Closes inmediately. Here is when I start to google for help.
I saw people with similar problems and someone recommended to look in the log file that PlexConnect creates, unfortunately there was no log file so I decided to Manually open the .py file and this is what I get
C:\PlexConnect>PlexConnect.py
01:00:53 PlexConnect: ***
01:00:53 PlexConnect: PlexConnect
01:00:53 PlexConnect: Press CTRL-C to shut down.
01:00:53 PlexConnect: started: 01:00:53
01:00:53 PlexConnect: Version: 0.5
01:00:53 PlexConnect: Python: 2.7 (r27:82525, Jul 4 2010, 07:43:08) [MSC v.1500 64 bit (AMD64)]
01:00:53 PlexConnect: Host OS: win32
01:00:53 PlexConnect: PILBackgrounds: Is PIL installed? False
01:00:53 PlexConnect: IP_self: xxx.xxx.xxx.xxx
01:00:53 DNSServer: started: 01:00:53
01:00:53 DNSServer: ***
01:00:53 DNSServer: DNSServer: Serving DNS on xxx.xxx.x.xxx port 53.
01:00:53 DNSServer: intercept: ['trailers.apple.com'] => xxx.xxx.x.xxx
01:00:53 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
01:00:53 DNSServer: forward other to higher level DNS: 8.8.8.8
01:00:53 PlexConnect: Shutting down.
01:00:58 DNSServer: Shutting down.
01:00:58 PlexConnect: shutdown
As I mentioned before I was Running Windows 10 so I Used PowerShell and from this window I get something different.
PS C:\PlexConnect> CMD.EXE /C PlexConnect.py
00:22:31 PlexConnect: ***
00:22:31 PlexConnect: PlexConnect
00:22:31 PlexConnect: Press CTRL-C to shut down.
00:22:31 Settings: add setting enable_plexgdm=True
00:22:31 Settings: add setting ip_pms=192.168.178.10
00:22:31 Settings: add setting port_pms=32400
00:22:31 Settings: add setting enable_dnsserver=True
00:22:31 Settings: add setting port_dnsserver=53
00:22:31 Settings: add setting ip_dnsmaster=8.8.8.8
00:22:31 Settings: add setting prevent_atv_update=True
00:22:31 Settings: add setting enable_plexconnect_autodetect=True
00:22:31 Settings: add setting ip_plexconnect=0.0.0.0
00:22:31 Settings: add setting hosttointercept=trailers.apple.com
00:22:31 Settings: add setting port_webserver=80
00:22:31 Settings: add setting enable_webserver_ssl=True
00:22:31 Settings: add setting port_ssl=443
00:22:31 Settings: add setting certfile=./assets/certificates/trailers.pem
00:22:31 Settings: add setting loglevel=Normal
00:22:31 Settings: add setting logpath=.
00:22:31 PlexConnect: started: 00:22:31
00:22:31 PlexConnect: Version: 0.5
00:22:31 PlexConnect: Python: 2.7 (r27:82525, Jul 4 2010, 07:43:08) [MSC v.1500 64 bit (AMD64)]
00:22:31 PlexConnect: Host OS: win32
00:22:31 PlexConnect: PILBackgrounds: Is PIL installed? False
00:22:31 PlexConnect: IP_self: xxx.xxx.x.xxx
00:22:32 DNSServer: started: 00:22:32
00:22:32 DNSServer: ***
00:22:32 DNSServer: DNSServer: Serving DNS on xxx.xxx.x.xxx port 53.
00:22:32 DNSServer: intercept: ['trailers.apple.com'] => xxx.xxx.x.xxx
00:22:32 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
00:22:32 DNSServer: forward other to higher level DNS: 8.8.8.8
00:22:32 WebServer: started: 00:22:32
00:22:32 WebServer: Failed to connect to HTTP on XXX.XXX.X.XXX port 80: [Errno 10013] An attempt was made to access a socket in a way forbidden by its access permissions
00:22:32 PlexConnect: WebServer not alive. Shutting down.
00:22:32 PlexConnect: Shutting down.
00:22:37 DNSServer: Shutting down.
00:22:37 PlexConnect: shutdown
PS C:\PlexConnect>
I Googled the error 10013 and it is related to Ports and it seems that something can be using my port 80, I looked in the CMD but NOTHING is Using my Port 80.
Honestly I dont know what else to try.
