There’s … a lot … of logs
There’s a 5.2 MB log at 7:57 am this morning, which (obviously) has a lot of stuff in it, but doing a search for ‘Database’ doesn’t show up much of interest, it’s optimizing the database a lot, and most of it is due to DVR/Live TV stuff which I’m not even using yet…
There’s a later log which has some odd things in it:
Aug 01, 2019 12:09:32.425 [0x7f5c467d3780] DEBUG - Performing a scan with 'Plex Series Scanner' (language: en virtual: 0).
Aug 01, 2019 12:09:32.425 [0x7f5c467d3780] DEBUG - * Scanning /raid/plex/television
Aug 01, 2019 12:09:32.425 [0x7f5c467d3780] DEBUG - * Scanning directory /raid/plex/television (parent: no)
Aug 01, 2019 12:09:32.425 [0x7f5c467d3780] DEBUG - Adding subdirectory for scanner: "/raid/plex/television/Octonauts"
Aug 01, 2019 12:09:32.425 [0x7f5c467d3780] DEBUG - Adding subdirectory for scanner: "/raid/plex/television/Blackadder"
Aug 01, 2019 12:09:32.425 [0x7f5c467d3780] DEBUG - Adding subdirectory for scanner: "/raid/plex/television/Red_Dwarf"
Aug 01, 2019 12:09:32.425 [0x7f5c467d3780] DEBUG - Adding subdirectory for scanner: "/raid/plex/television/The_Dresden_Files"
Aug 01, 2019 12:09:32.425 [0x7f5c467d3780] DEBUG - Adding subdirectory for scanner: "/raid/plex/television/.grab"
Aug 01, 2019 12:09:32.425 [0x7f5c467d3780] DEBUG - Adding subdirectory for scanner: "/raid/plex/television/Firefly"
Aug 01, 2019 12:09:32.425 [0x7f5c467d3780] DEBUG - Adding subdirectory for scanner: "/raid/plex/television/ûlYÂ≤ôd$::ôÛÚ,œÖªÃ∂ÂèlAµ‚$ë≠XRÈ–;ª
kD>Rúa„‡ã{{è¢C…#I…ÁÄ{‘
4ç8Ò3\qJc"
Aug 01, 2019 12:09:32.426 [0x7f5c467d3780] DEBUG - Skipping over directory '', as nothing has changed; removing 0 media items from map.
Aug 01, 2019 12:09:32.427 [0x7f5c467d3780] DEBUG - * Scanning directory /raid/plex/television/ûlYÂ≤ôd$::ôÛÚ,œÖªÃ∂ÂèlAµ‚$ë≠XRÈ–;ª
4ç8Ò3\qJc (parent: yes)
Aug 01, 2019 12:09:32.427 [0x7f5c467d3780] DEBUG - Adding file for scanner: "/raid/plex/television/ûlYÂ≤ôd$::ôÛÚ,œÖªÃ∂ÂèlAµ‚$ë≠XRÈ–;ª
4ç8Ò3\qJc/Ω죜"
Aug 01, 2019 12:09:32.427 [0x7f5c467d3780] DEBUG - Skipping over directory 'ûlYÂ≤ôd$::ôÛÚ,œÖªÃ∂ÂèlAµ‚$ë≠XRÈ–;ª
4ç8Ò3\qJc', as nothing has changed; removing 0 media items from map.
Aug 01, 2019 12:09:32.427 [0x7f5c467d3780] DEBUG - * Scanning directory /raid/plex/television/Firefly (parent: yes)
Aug 01, 2019 12:09:32.427 [0x7f5c3562f700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%20%9ElY%11%E5%B2%99d%1A$%3A%03%02%02%04%3A%99%18%F3%04%F2%2C%1A%CF%85%BB%CC%B6%E5%8FlA%0E%B5%1C%E2$%91%ADXR%E9%D0;%BB%0A%20%1Fk%1C%1ED%3ER%9C%07%E3%E0%1F%8B%7B%7B%8F%A2C%0B%C9%23I%C9%E7%80%7B%17%D4%17%0D4%8D8%F13%5CqJc
Aug 01, 2019 12:09:32.427 [0x7f5c467d3780] DEBUG - Adding subdirectory for scanner: "/raid/plex/television/Firefly/Season 01"
Aug 01, 2019 12:09:32.428 [0x7f5c467d3780] DEBUG - Skipping over directory 'Firefly', as nothing has changed; removing 0 media items from map.
Aug 01, 2019 12:09:32.428 [0x7f5c467d3780] DEBUG - * Scanning directory /raid/plex/television/Firefly/Season 01 (parent: yes)
I don’t know what the .grab directory is (I certainly didn’t make it) and I’ve no idea what the weirdly-named directory is - it’s not there now. I’m assuming that’s some sort of machine-generated directory…
Right now, all I see is:
[root@lyonesse television]# pwd
[root@lyonesse television]# ls -la
total 0
drwxrwxr-x. 8 plex plex 139 Jul 28 17:14 .
drwxr-xr-x. 5 root root 71 Jul 29 06:57 ..
drwxrwxr-x. 7 plex plex 115 Jul 31 16:43 Blackadder
drwxrwxr-x. 3 plex plex 31 Jul 25 19:03 Firefly
drwxr-xr-x. 2 plex plex 10 Jul 24 23:03 .grab
drwxrwxr-x. 3 plex plex 31 Jul 15 20:28 Octonauts
drwxrwxr-x. 10 plex plex 178 Jul 22 07:07 Red_Dwarf
drwxrwxr-x. 3 plex plex 31 Jul 22 17:11 The_Dresden_Files
[edit]
Ok, the library scan has finished, and there’s no improvement. Still missing the shows in both ‘television’ and ‘movies’. Logs attached:
Plex Media Server Logs_2019-08-01_12-54-10.zip (2.6 MB)
