Loudness leveling, gapless, Plex music
Hi!
What devices support loudness leveling and gapless playback? I’m mainly interested in Airplay and Chromecast Audio.
Does Plex use ReplayGain tags for loudness leveling?
I know I need Plex pass for this features.
Regards
Bernt
Just the iOS, Android mobile apps at the moment.
Yes I am told we use ReplayGain
Only the algorithm from ReplayGain is used. (ReplayGain v2, to be precise)
But Plex will not read ReplayGain values from embedded meta tags. Instead it will determine these values itself and store them in its database only.
Great, thanks for the quick reply.
I assume it only works on the iOS device it self and not the Airplay device?
Regards
Bernt
Chromecast is currently not working, yet. But AirPlay should be.
That’s wonderful. I better get a pass to try it out. Thanks!
Regards
Bernt
