Server Version#: 1.41.3
Player Version#: safari
is it only me or Plex Media Server doesn’t launch anymore with Mac OS 15.2?
it just doesn’t start at all, no icon, no nothing.
I’m not aware of a general issue.
If the Plex Media Server won’t start and doesn’t even get to the stage where it’ll be writing to the server logs, you can attempt the following procedure to see if there’s any error messages on the OS level:
- Open Finder and navigate to
/Applications - Select
Show Contentfrom the context menu of thePlex Media Server.appitem - Navigate to
Contents/MacOS - Open the
Terminalapp - Drag the
Plex Media Serverexecutable from the Finder window (#3) into the Terminal Window and pressReturnto execute it
This is no different from running the app, so it won’t succeed – but you should get a more specific error message about what’s causing it to fail starting.
oh, ok thanks.
I got this:
libc++abi: terminating due to uncaught exception of type soci::soci_error: sqlite3_statement_backend::prepare: database disk image is malformed for SQL: PRAGMA cache_size=2048
****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: DBF1CC95-D1AD-44A0-BF74-8F71F0D1D371
tommaso@macmini ~ %
Then there you go…
https://support.plex.tv/articles/repair-a-corrupted-database/
or maybe the powerhouse solution
I solved, thank you lots
