Machine Learning for Playlist Generation (Using for example DeejAI)
There is a cool tool called Deej-A-I using Python to automatically generate playlists from a music database.
I’ve been looking at how to manually run it to generate playlists, but it would be way less of a hassle to use if it was built into Plex itself.
Could also replace the Radio feature, and extend Radio to ALL tracks, even individual tracks.
Infact, as i understand it, it can even generate playlists from playlists - meaning Plex could end up generating it’s own playlists ala how Spotify does it for the Discover Weekly and Release Radar (Just, not exactly that)
Github link: https://github.com/teticio/Deej-A.I. (Gotta add the . yourself, Chrome seems to strip it when you click the link)
Example after having scanned 320k tracks on Spotify: https://deej-ai.online/
You might want to check out “Mixes for You” from the new Super Sonic feature
Considering this to be implemented.
Holy f…! this is amazing, thanks! definitely getting turned on ASAP :smiley:
