Following the loss of English tv in Spain people have been searching for a solution in iptv. The Mag 250 has a linux os and the 260 uses Android. I dont think you can add apps. Does anyone know if Plex works or is compatible with either of these boxes?
UP.
They got some new portal with app kit
http://community.infomir.eu/
Can someone add plex app for mag, or says that it impossible ?
I’d love that too.
Same here… ALOT of people use that MAG devices. would be awesome with a plex plugin.
May be we are wrong? Is it possible what some existing Linux version (for embedded devices, as for example), already is compatible with MAG250?
I have added the link for plex server to my mag254 box, and am able to access as far as the login screen, but when clicking on sign in, it does nothing apart from refresh and then change to log out, no credentials have been added either, I have also tried using a token like an SSO access point, but still nothing, has anyone had success adding a token to mag and getting access?
Contact me if you wish to be able to see English TV in Spain or in other place again.
