I’d like to structure my movie series’ such that they maintain correct movie order in their respective directories.
e.g.
/The Before Trilogy
… / 1. Before Sunrise (1995)
… / […files]
… / 2. Before Sunset (2004)
… / […files]
… / 3. Before Midnight (2013)
… / […files]
Naming it in this way allows me to maintain movie order on my hard drive but in Plex it often causes the scanner agent to include the number (i.e. 1, 2, or 3) in the movie title, and so I lose important metadata as it’s treated like an unknown video.
i.e. there’s no movie called “1 Before Sunrise” but there is “Before Sunrise”
How can I maintain movie ordering on my hard drive without affecting Plex agent? Perhaps a setting in plex or a better naming convention?
Though I don’t really recommend it and it does not follow official naming convention. There was another user I know puts the year first in parenthesis and seemed to be working fine for them.
I’m pretty sure even without Plex they want when ordered by title on their filesystem to ordered in release order. Else “Before Midnight (2013)” would show up first in file system in the trilogy folder.
Could manually match after scanning them in but I get that may be a lot of work depending on how many of these groups they have.
Yeah, I’ve got a lot of collections like this so manually finding the metadata would be quite tedious.
I’ll try renaming a collection with the year at the front and see if Plex can successfully identify the movie.
Re: IMDB ID - Are you saying that adding the ID to the title will allow plex to identify the movie regardless of whether I have a number at the beginning (e.g. “3. Before Midnight (2013 [tt2209418]”)?
And there is another trick which could benefit your use case:
The content of the first pair of square brackets in the folder/file names is ignored during matching. So you could do something like this:
/The Before Trilogy
… / [1] Before Sunrise (1995) - {imdb-tt0112471}
… / [2] Before Sunset (2004) - {imdb-tt0381681}
… / [3] Before Midnight (2013) - {imdb-tt2209418}
without fearing that the numbers at the beginning could disturb the matching process.
