Ok then since ad supported content will never be recordable I will probably just remove it. That doesn’t change the fact that it takes too many clicks to get to the dvr agenda view. This request is about making it easy to get there and add better functionality to that screen.
Yes the continue watching and recently added hubs usually do not show what I wish to see or there are too few items on the screen.
So… it comes down to Tiebierius summary from above:
You’re asking for
Thanks for clarifying ![]()
I still don’t understand the comment about a long press to get into the options to delete a program. What is that about? Imho it is not obvious.
On a mobile client you can access the context menu of items in your library or hubs by long-pressing that item. In Plex Web you can achieve the same by clicking the 3-dots on the poster when hovering over it.
What about roku app? Does the roku app have a long press?
bump again
bump again
bump again.
Just a note… you gain nothing by bumping your own suggestion.
At worst, the bumps drown the actual content of the thread and make it harder to get people to vote for it (walls of text tend to be ignored).
