Making dynamic playlists
Server Version#: 1.21.0.3616
when I make dynamic playlists i want to also use make playlists with vid’s with spec length
I know i can sort the files after play length, but as i can’t add multible files from library view, it’s rather diff to make a playlist based on play length.
I s it possible to add length to the drop down list in the user defined custom filter page view - that way you can filter the length of videos and then add them to a dyn. playlist
You can filter almost everything else than the length of the movie
Actually you can add multiple files from library view:
[HowTo] Create Playlists
As for adding length to the custom filters, you might do a quick search in the Feature Suggestions forum to see if anyone has requested that before. If you find one you can add your vote. If not, you can create a new thread to request it.
About the Feature Suggestions category
Thanks for your answer
I know that i can add multible entries, by selecting each item add the time until all that i need to work with are chosen - but that’s takes a lot of clicking and is time consuming - that’s why the filter selection option is a very handsome tool in selecting - I might have over 10.000 entries in my library view and might need to select all that plays between 2 min and up to let’s say 10 min - that could easily be around 500 entries, that’s why it’s so much easier to use the filter instead - the problem though is that you can’t choose length as a filter option.
