Manage screensaver
After 5 minutes, a screensaver appears on the TV with photos of the films, etc., as well as music and film extras. Can I disable the display of photos of extras and music?
Is this an app on your TV or are you using a device like a Apple TV or Roku? (screenserver settings would not be related to the server)
If you are using Plex HTPC or our Smart TV app then in Settings>Experience you can change the Screen Saver Type to Plex Logo. If you want no screensaver at all then set the Screen Saver setting from 5 minutes to none
Okay, but I do want a screensaver with pictures from movies and series. I wanted to know if I can turn off the pictures of my music and the movie extras. But I don’t think that’s possible.
It is based on content from the libraries that are pinned/favorited to the side bar. So you could unpin the music library but then you would need to hit MORE at the bottom of side bar to get to that library.
Okay, thanks a lot!
