Hello,
Accordingto Logs my current Encoding Settings for playing stuff via Web Player are:
Oct 06, 2017 15:19:35.518 [0xec335b40] DEBUG - Job running: EAE_ROOT='/volume1/Plex/tmp_transcoding/pms-1641f8d3-4871-44bc-bc29-752ed61a675b/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/volume1/Plex/Library/Application\ Support/Plex\ Media\ Server/Codecs/798f007-1247-linux-synology-i686/' XDG_CACHE_HOME='/volume1/Plex/Library/Application Support/Plex Media Server/Cache/' XDG_DATA_HOME='/volume1/@appstore/Plex Media Server/Resources/' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxxe/Plex Media Server/Plex Transcoder' '-codec:0' 'hevc' '-codec:2' 'ac3' '-i' '/volume1/PUBLIC/Filme/Serien/Black Lagoon/Black Lagoon 03 Ring-Ding Ship Chase (BDRip 1080p AC3 10bit).mkv' '-filter_complex' '[0:4]scale=1920:1080[0];[0:0][0]overlay[1];[1]scale=w=1920:h=1080[2];[2]format=pix_fmts=yuv420p|nv12[3]' '-map' '[3]' '-codec:0' 'libx264' '-crf:0' '16' '-maxrate:0' '10116k' '-bufsize:0' '20232k' '-r:0' '23.975999999999999' '-preset:0' 'veryfast' '-x264opts:0' 'subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none' '-force_key_frames:0' 'expr:gte(t,0+n_forced*1)' '-map' '0:2' '-metadata:s:1' 'language=jpn' '-codec:1' 'aac' '-ar:1' '48000' '-channel_layout:1' 'stereo' '-b:1' '256k' '-f' 'dash' '-min_seg_duration' '1000000' '-skip_to_segment' '1' '-time_delta' '0.0625' '-manifest_name' 'http://127.0.0.1:32400/video/:/transcode/session/3us1ykc2oq5nz3orjejri0i5/eceedb21-ad68-442e-a2c4-f1fc4fadd2d9/manifest' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' '-movflags' '+faststart' 'dash' '-start_at_zero' '-copyts' '-vsync' 'cfr' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/3us1ykc2oq5nz3orjejri0i5/eceedb21-ad68-442e-a2c4-f1fc4fadd2d9/progress'
I’ve tried the Advanced settings changed the “TranscoderH264Preset” to medium worked even the “TranscoderH264OptionsOverride” worked after a reboot.
The thing is… it’s (as described) not an override but an Append.
The thing is, this is the only 1080p option available:
I’d rather use a higher crf around 20 and some other settings like a special -tune option from ffmpeg.
Is it anyhow possible to modify these settings?
