You really think it’s possible that this is necessary? or it could fix stuff ? I just found the “exportTools” plugin. So this could work.
Is it possible to not create the 500GB of thumbnails/chapters again ?
okay, it’s one thing to have that much bugs (4 different bug-reports open) … pretty annoying
but to have ZERO support FOR 1 WEEK is another thing.
i’m trying to HELP YOU to fix YOUR system. i mean… do i make my money with it or you do?
this Thread so far?
Buggy Menus = solved by daily database optimization (PLEX FAULT)
HW Transcoding = plex showed it up as working (HW), but wasn’t (PLEX FAULT)
not MY fault
so if you take these bug’s seriously (and fix them), this thread already could helped others
You don’t seem too interested to work with me or we have a communication barrier I can’t overcome.
I asked about creating a new “Library” instance. You’ve ignored that / deflected.
You don’t want 500 GB of thumbnails? Turn them off when you create the library section or click “Delete Thumbnails” in each Library section -> Advanced tab.
I’m not a gui person so can’t help with Plex/Web (long since and well established in these forums, thank you)
I am turning this thread over to another team member in hopes of resolving your issue.
You found a bug in post 18 that’s serious and not your fault, and I wanted to hop on and link a similar thread where we got a helpful reply. You may be facing similar issues.
