Mark as Played stopped working randomly
Server Version#: 1.32.5.7349 via Docker - UnRaid
Player Version#: Apple TV Plex App, Plex/Web Local and Remote
As of a week ago, my Mark as Played as well as the natural mark as played at the conclusion of a file stopped updating. No matter if I do it manually or naturally all shows and movies stay flagged with the un-played flag. If I take an older show/movie that has already been marked as played, I can mark it as un-played and then update it to played and that works.
I am running the latest docker container.
I have completed the Optimize Database and Clean Bundles.
I have tested the library function in the AppleTV Plex app as well as the Plex/Web app via Firefox PC.
I have removed and re-added the docker container (using the same app data files)
The only thing I have not done is to remove my app data folder and “start over”.
I cannot find this topic arsing so I am not sure where things may have gone wrong. I hope someone else h
Any insight would be helpful.
Plex Media Server Logs_2023-09-16_21-36-39.zip (3.6 MB)
Unfortunately your primary database file is damaged.
You need to urgently either
Here is a handy script to repair the DB for you: GitHub - ChuckPa/PlexDBRepair: Database repair utility for Plex Media Server databases
Thank you for the rapid reply. I was afraid of that. I was ultimately not able to do the repair, but had to do a dump and read to make a new database file and all is now well!
In case someone else stumbles upon this and also uses Plex in Docker - here are the steps in a handy YouTube Video: https://www.youtube.com/watch?v=2ZDX7Gq7UFU.
Community forums for the WIN!
That’s what the above linked script is doing. :slight_smile:
