Media Distorts Every Few Seconds Randl
Hey Guys -
I’m a long time Plex user and currently run PMS 1.13.9.5439 on a Windows 10 x64 system. Most playback is performed on the same system as PMS, on another LAN-connected PC, or a couple of LAN-connected Raspberry Pis running RasPlex, and sometimes mobile devices.
Recently, I ran into an issue where during playback on all devices including local to PMS; the audio (and sometimes video) distorts for about a second - sometimes dropping out altogether. After that second, it resolves itself although it takes ~3 seconds to do on the RasPis. This occurs randomly every 15-120 seconds. Below are some tests I’ve performed with results, what I’m thinking of now, and system specs.
Any suggestions? Thanks!
Tests I’ve Performed
  • Reboot host: No change
  • Played different videos / formats / resolutions: Exists in all of them with no real difference in the effect or timing of it
  • Scanned Media Files: Used the multiplexer in MKVToolNIX to reprocess a couple of titles which usually resolves errors. No change
  • Playback in VLC: I attempted playback of the same titles I’m testing with in VLC. The errors still occurred, but seemingly recovered much faster - perhaps due to limited transcoder settings used in PMS
    Resource Usage: I always monitor resource usage as my PC is multipurpose, but during playback everything is at 50% usage or lower (CPU, RAM, GPU)
Current Thoughts of Cause
  • Drivers? Doubt this as no drivers have been updated recently besides video (Nvidia) and would be surprised if related to that as audio is also affected
  • Codecs? I’ve used codec packs in the past, but haven’t ever installed them in my current build nor recently installed / updated any media-related apps beyond PMS updates
  • Recent PMS Update Bug?: I am a Plex Pass member, am subscribed to the Beta channel, and currently running 1.13.9.5439. Has anything like this been reported? Yes, I did test with VLC, but perhaps the update included something system-wide like an updated codec?
System Specs
  • Intel I7-3770k (OC’d to 4.0Ghz)
  • Gigabyte GA-Z77X-UD5H Motherboard
  • 32gb RAM (x4 - 8gb GSkill RipjawsX F3-1600C9-8GXM)
  • Expansion Cards
  • Nvidia Geforce GTX 970
  • RocketRAID 2720 SAS Controller (Use x2 SAS->x4 SATA fan-out cables to provide more SATA ports)
  • USB 3.0 Controller Expansion card (x4 additional external ports and x2 internal)
  • Storage (14 disks total)
  • C:\ - 256gb Samsung 850 Pro - SATA (OS & Apps)
  • D:\ - 43.5tb Disk Pool (Use Stablebit DrivePool which ties together 11 platter disks & 1 SSD for caching) (Media and file storage)
  • E:\ - 1tb ST1000LM014-1EJ164 SSD/Platter Hybrid (App installs & Plex Cache)
  • G:\ - 256gb Samsung 850 EVO (Oculus Games / Apps)
  • Nzxt GRID+V2 Fan Controller + x4 200mm fans + x4 120mm fans (13 Platter disks get hot!)
  • Cooler Master Hyper 212X - CPU Cooler with Dual 120mm PWM Fans
  • Oculus Rift
  • Windows 10 x64 Pro (1803)
Thanks!
