Media Metadata Questions
First time posting, so forgive any ignorance on my part for this post. I’ll provide as much description as I can initially, and will gladly provide additional details upon request. I’ll summarize the post with questions and system details at the end.
I am running Plex in a docker container (using kitematic and the plexinc official pms-docker pre-built container) on Ubuntu 16.04. I initially setup Plex (without docker) on Ubuntu 18.04, but ran into some issues. So I did a fresh install of 16.04 and started using the docker container as counter measures to the issues I experienced the first time and the server has run beautifully ever since, with one tiny exception. Due to the nature of docker containers and the pre-built container I chose, I cannot update to the latest version. I’d like to setup a new container, but I’m concerned about losing the media metadata customization I’ve added through Plex’s interface. Once I am able to answer the questions below I’ll rebuild the container and then upgrade my OS back to 18.04.
  1. Is there a good program (and stepXstep guide) I can use to modify the file metadata after they’ve already been created? (This is my preferred method of handling the situation so that I can clean up episode names, etc. Going forward I will modify the info in Handbrake when I create the .mp4, but I’d already ripped 3+ boxes full of media before I figured out I should do that.)
  2. Is there a way to backup, export and later import the Plex metadata for when I rebuild the container?
OS: Ubuntu 16.04 64-bit
Container: plexinc official pms-docker
RAM: 8gb
CPU: AMD Athlon II X4 650
Graphics: Geforce GTX 1050 ti
So I feel a little dumb. After posting I started experimenting with a second docker container and realized that the config directory and transcode directory are external to the docker container so pointing the new container at the directories solved the maintaining metadata issue.
Since that is all it takes, I guess I answered my own questions.
