Media Server Gone ........again. HELP!
For several days I have not been able to access my server. Would you recommend to remove it all and start a new one all over again? The last time I took me TWO days to upload my entire file collection. Someone asked me how I set it up from the start and I can only say that I installed the program on my computer then I followed the motion of adding libraries (folders with movies such as western, sci-fi, etc, etc) and that’s it. I am using windows 10. My server has been unreliable from the beginning.
What do you mean by gone? Is it still running and you can’t access it or does it disappear from the computer all together?
The server “Marco2Samsung” is unavailable
Plex will automatically try to reconnect to this server
I have been receiving this message for a week now…
This just started happening to me as well. When i reboot it is PMS appears to be gone. Same message.
I deleted PMS and started over. Took days for the library to upload. First reboot and it is gone again, same thing all over. Ive tried logging out, rebooting, shutting down etc. Running on a MacPro, everything up to date.
I ended up deleting the old and troublesome server I had; and I opted for creating a new one; I called it Phoenix :-). It took me a few days to upload but it is working nicely so far.
Cheers
Thanks for the tip. I’ll apply it to the newly-created server.
