So I’m unfortunately not even sure this is the correct forum, but it just might be.
My problem is quite obvious if you would be so kind to have a look at these (five) attached (well, actually they’re contained in the following link) pictures:
http://min.us/mvfGswR
My preferred view is the one in the pictures. However, I find it immensely annoying that this does not work for individual seasons of TV shows, and Metadata can’t be modified manually either (which I would be willing to do), since this option is greyed out.
Any help on this? Oh, the Skin is Lithium, by the way.
Thanks in advance!
