metrics.plex.tv
Why did Plex change from metrics.plex.tv in 1.9.4 to something else in 1.9.5 for their statistics gathering? I’m not looking to start another firestorm just curious to why.
If you opt out of sending optional playback data here (Bitrate, Duration, Resolution, Offset, Completion Status) you shouldn’t see any metrics.plex.tv connections anymore.
However since Plex is still collecting non-anonymized playback data (tied to your account) even if you opt out of optional playback data, you need to block analytics.plex.tv as well.
I’ve checked my PiHole Log and besides analytics.plex.tv and metrics.plex.tv there is nothing you can block without affecting functionality.
Personally I also added news.provider.plex.tv because there are no german news outlets yet so it currently has no value to me.
I had metrics.plex.tv blacklisted in pihole but after the 195 update I never seen any entry blocks. Today I downgraded to 194 and metrics is back which leads to believe they changed to some other avenue.
Thanks for the headsup about analytics.plex.tv!
Would still be curious as to what they changed it to! and Why!
@Wiidesire thanks for the 3 addresses you provided. Promptly blocked.
Anybody knows how to block “URLs” (DNS entries?) instead of IPs in linux? Like with ufw? :slight_smile:
Be careful blocking news.provider.plex.tv as it will have unintended results…
Which is what? No news category is plopping up in the Android TV interface, haven’t seen any side effects.
@flow said:
Sorry, I don’t know. But you can try to use your hosts file… Just as an idea…
That would be easy, thanks for the hint :slight_smile:
I don’t know any out-of the box solution. But it should be fairly easy: just write a script that reloads the iptables rules once a day. That script can than do a dns lookup and do the substitution.
Other option: I’m running a central dns server for my home-network on my firewall. I’ve configured it in a way that e.g. metrics.plex.tv always translates into 127.0.0.1… Basically the same that Pi-Hole does.
Alternative: you can still write the above translation locally into the hosts file and change resolv.conf to look into that before doing a dns lookup.
