Missing update in forum for latest beta build
Fortsetzung der Diskussion von Plex Media Server:
Hey guys,
Yesterday I updated my PMS on Ubuntu to version 1.29.0.6140. However, there’s no changelog on the forum or a post about it. Just wanted to raise awareness, that it’s still missing.
Best wishes :slight_smile:
EDIT: Not sure which forum tag to apply, please change as needed
I suspect this release got pulled. I too got a notification for a server update but later when I went to do the update it was gone. Version Version 1.28.2.6151 is the current beta version I have installed and its reported as up to date.
Yeah, it looks like it. Now I’m on the pulled version, rip :joy:
If I was you I’d stay on the version you have unless you run into problems. When a later version comes in the not to distant future plex should then just update to it.
You can of course downgrade but to be honest I never do that myself. Should be fine but I just don’t trust downgrades :slight_smile:
Yeah, that’s exactly what I thought. Downgrades sometimes make more problems than staying on another version until there’s a proper update.
Same thought and thank you for chiming in! Will just wait it out :upside_down_face:
I also jumped on the update right away, not noticing that the build number was actually lower than the previous (now again current) release. If you’re interested, here’s the changelog for the pulled update:
ITEMS ADDED:
  • (Windows) Add 64-bit x86 Windows builds
  • (Windows) Support zero-copy hardware transcoding with Nvidia GPUs on 64-bit Windows
ITEMS FIXED:
  • (HTTP) Certain client apps could quit unexpectedly when connecting to a server during startup maintenance (#13802)
  • (Music) Locking the date field for albums wouldn’t lock the year value (#13786)
  • (Scanner) Improve scanner performance (#13804)
Thank you very much for providing me with the changelog :ok_hand: Much appreciated
