More control on radios / auto play
Server Version#: 1.32.8
Player Version#: plexamp 4.9.1
Radios are great, but I’d like to have more control on them.
For example, I’d like to launch a random album radio for one or more specified artist, not the whole library (because I’m in the mood for them and not others).
I haven’t found a way to do that quickly.
Another one is the autoplay after an album. Adding the next/previous album for this artist is okay, but it could be greatly improved with the possibility to launch a configurable radio instead.
How about Artist Mix Builder?
You can swipe the card at the bottom of the up next section to pick from
  • silence → end playback
  • next album
  • similar album
  • artist mix
  • artist radio
  • track radio (based on final track in the queue)
  • a random(?) radio, e.g. „The 2020s“
  • library radio
This create songs mixes where I’m looking for albums mixes (this is super important for me, cf Android auto: next album from hardware keys - Plex Labs - Plex Forum)
At the bottom of the track in the player? I don’t see it, cf capture (I deactivated autoplay here)
That’s probably it.
With autoplay I only get the next album of the current artist (is there a way to have miniatures of image uploads?)
Can you swipe the box that says Album suivant to the left/right?
Edit:
You should be able to select a % when uploading an image to define the size used to display inline. You can also assign any %age when editing your post (see the change I’ve made to your previous post, adding ,25% as a suffix to the image code)
Indeed, that’s good. :slight_smile:
I would prefer something more automated (@ work focused, or for android auto) but it will work for the time being
