More than 20 Maximum simultaneous video transcodes
Plex Server Version#: 1.41.0.8939
Proxmox: 8.2.4
Hardware Passthrough: Intel Arc 380
VM OS; Ubuntu 24.04.01
VM Kernel: 6.8.0-41-generic
I have been testing transcoding performance in this configuration and have gotten fantastic results transcoding 4K high bitstream HDR 10+ (with Atmos) movies to a whole variety of different 1080 / 720 / 480 formats using tonemapping. I have tested the system to 20 simultaneous HW transcodes and have hit the limit in the gui:
  • Maximum Simultaneous Video Transcode
The current limit is 20
Q: Is there a way to increase this beyond 20?
Unlimited (top of list).
WOW what CPU you running with that card?
You have a mix there! How about all 4K streams how many can it handle?
I’m curious about the total bitrate flowing into and out of the card.
I was wondering how anyone could’ve missed that, so I went to check, and that drop-down box has a limit of 20 items, lol. So, if someone previously set it to 20, the unlimited option is not shown (you have to scroll up).
You all know I’m going to ask —
:smiling_imp:
More than 20 simultaneous users?
Customers ?
:thinking:
Do I want to know? :rofl: ’
LOL!
Yeah. . .
Thanks. Not sure how I missed that. Would still be nice to set a limit once I find out what it is.
No. I put the system together and I want to know what it can do. I dont really expect that I will ever have more than 5 or so running simultaneously. Call it; morbid tech curiosity.
I am happy to run a test and let you know.
What would be of most interest to you?
Examples:
  • High bitrate input video (4K @ 25+ Mbps) transcoded to something small (720 @ 2 Mbps) * Edited this line to correct the stated bitrate
When I did the initial test, it was a mix of higher bitrate videos kicked out to mostly 720 / 1080p at a mix of bitrates. All of the videos had 7.1 TrueHD audio. I think all of that transcoding happens on the CPU.
LMK what you are interested in.
AMD Ryzen 7950x is the CPU under Proxmox. It doesn’t require a CPU like this, it’s what I had.
The VM guest running Plex has:
  • 8 CPUs passed through to it (Host Type)
  • 8 GB of Memory
  • Machine Type: Q35
  • Bios: OVMF (UEFI)
Yeah. It was an dumb miss. Maybe a UI suggestion would be to move the Unlimited to the bottom of the list below 20? To be fair, it’s a nit. I should have seen it. I was hoping that I could bump it to like 35 or something and that was the context of my question.
@nwolfe_stealthturtle.com
Using a source file of 40 Mbps HEVC, HDR, (tonemapping enabled),
Start a playback session which transcodes to 20 Mbps 1080p
Wait 20 seconds (get past the opening credits)
Start another session with the same file.
Repeat until the output starts getting jittery / laggy
Share how many sessions you can play without issue please
OK. I started a slightly different test before I saw your response. I will perform the test as you’ve indicated shortly.
**Test 1: Mixed Input Bitrates of 4k Movies (20 different movies)
  • Average Bitrate of Input Files: 29.795 Mbps
  • Audio Formats of Input Files: TrueHD 7.1 (16) DTS-HD 7.1 (3) EAC 5.1 (1)
  • DataRate In: Range [441 Mbps - 827Mbps]
  • DataRate Out: [104 Mbps - 187 Mbps]
  • CPU Usage: [ 73% to 94%] (8 cores)
  • GPU Usage: [61% to 91%] (Arc A380)
  • Memory Usage: 2.75 GB
  • NAS IOPS: 580 Ave
  • Test Duration: Roughly 40 mins
Observations:
  • It looks like the limit of this setup may be about 20. Things are getting slower as I started the last movie. (CPUs?)
  • I am getting close to maxing out the CPUs and I think this is the Audio transcoding happening. I have more cores to throw at it and I may increase the number I am throwing at this VM later just to see if that changes anything. I’ll leave it as it is for the test you’ve asked for.
  • I am quite happy with the cost / performance of this Arc 380 as a transcoding device. I didn’t think it would be capable of this for $115
  • Another limit I may run into soon is my NAS. It’s a 4 disk NAS that stores my videos attached via NFS. It does have a couple of SSDs in it for faster read / writes but the sustained output this test requires probably is forcing the reads from the mechanical disks mostly
I’ll run the test you defined as soon as I can tear this one down and start another.
Note for folks reading this:
I am just a dude that works in tech that was curious about how far I could push this setup. My main objectives were to Proxmox Passthrough a Video card to a VM to offload the transcodes so my kids could watch the 4k videos in my library. I’m happy to answer questions about my setup if you have them. I am not an expert in video transcoding though.
If I’ve understood your question correctly: All of the source files were 4k in that test. I was transcoding them down to a variety of resolutions and bitrates under the assumption that one would be likely to see users using different rates depending upon the device they view on.
Thank you for that but it’s not what I asked for.
I had requested the SAME FILE be used multiple times.
Using this method, it would be easy to calculate actual input and output bit rates as well as CPU load for audio conversion.
Using various files and reporting “average” tells us nothing.
Based on card specs, I can only estimate you’re probably seeing about 120 Mbps video processing capability. How you slice up that 120 Mbps does not matter. It could be 60 sessions at 2 Mbps for all it cares.
I had hoped we’d have real-world performance with PMS so others can gauge
If you do get chance to run it… When it does fail, See where it stammers – Which limit is it butting up against. Video, Render, Open/CL ?
TEST 2
The closest file I have to what you are asking for is 43.3 Mbps HEVC. Here are the details:
Test Media Data
  • Duration 1:32:24
  • Bitrate 43378 kbps
  • Width 3840
  • Height 1608
  • Aspect Ratio 2.35
  • Video Resolution 4K
  • Container MKV
  • Video Frame Rate 24p
  • Video Profile main 10
  • Audio Codec TruHD
  • Audio Channels 7.1
  • Codec HEVC
  • Bit Depth 10
  • File Size 37.79 GB
I performed the test you asked with that file:
Test Setup
  • Rebooted System (Guest VM)
  • Source file 43.38 Mbps - HEVC, HDR
  • Tone mapping enabled
  • Start a playback session which transcodes to 20 Mbps 1080p
  • Wait 20 seconds (get past the opening credits)
  • Start another session with the same file.
  • Repeat until the output starts getting jittery / laggy
Test 2 - Results:
  • everything ran perfectly through 7 simultaneous Transcodes
  • At 8 - I started to get occasional and very brief pausing and short waits (1-5 seconds). The video would automatically restart. This settled out after a minute and things began to run smoothly without further issues.
  • Adding a 9th stream increased pausing and caused occasional hangs, forcing a shuffle or transcoder bitrate change to get them re-started. This would then result in another stream pausing.
Comments & Observations:
  • Simultaneous Transcodes: I would say the effective limit in this set of test conditions is clearly 7 transcodes as adding additional would begin to impact the user experience
  • IO: Using the same file for all streams in the test removes disk IO as a concern as that files caches to SSDs on the array
  • CPU: utilization remained low throughout this test and was of no concern that I could tell
  • Network: Network bandwidth averaged ROUGHLY: In 325 Mbps - Out: 155 Mbps Network wasn’t stressed and the data rates seem in-line with what I would expect
  • Scenario: It seems that mixed bitrate streams is a more likely real world scenario (at least for my library) and will increase the number of effective simultaneous transcodes as my previous test seems to indicate.
Added Later - Additional Comments on LIMITS:
  • Limits: Looking at the output of ‘intel_gpu_top’ the limit appears to be in “video”
  • “video enhance” utilization appears roughly 20% below “video” in the output
  • “render” & “computer” are not indicating as utilized in the output
  • “Video0 & 1” appear to be running at an average of 55% when running 7 streams
  • Starting new streams jumps these (video) both to 100% for about 15/20 seconds (Assuming this is the engine filling the buffers of clients)
  • Adding an 8th stream in this test condition causes video0&1 (On intel_gpu_top) to persistently spike to 90%+ with occasional holds at 100% (We appear to be at the limit here)
Thoughts or questions anyone?
See the follow up test I conducted using the method you’d asked for.
I hear Nerd Statistics is coming to Plex soon so these tests will be great to see the actual bitrate being processed/received on the client.
They should be in the 10.21 Android client (beta)
Here’s 5 instances of the same movie transcoded to 20 Mbps.
2 browsers, 1 ipad, 1 iphone, 1 web browser.
I can add two TVs tomorrow.
I will get more spun up (2 more) but there’re no issues.
285 Mbps input - 100 Mbps output. - tone mapping.
30% utilization , 24 watts.
[chuck@lizum ~.1999]$ nvidia-smi
Wed Sep  4 01:53:14 2024
| NVIDIA-SMI 550.107.02             Driver Version: 550.107.02     CUDA Version: 12.4     |
| GPU  Name                 Persistence-M | Bus-Id          Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |           Memory-Usage | GPU-Util  Compute M. |
|                                         |                        |               MIG M. |
|   0  NVIDIA RTX 2000 Ada Gene...    On  |   00000000:01:00.0  On |                  Off |
| 30%   48C    P2             24W /   70W |    3687MiB /  16380MiB |      8%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                              GPU Memory |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A      3423      G   /usr/lib/xorg/Xorg                            200MiB |
|    0   N/A  N/A      3892      G   /usr/bin/gnome-shell                          119MiB |
|    0   N/A  N/A     20391      G   ...bian-installation/ubuntu12_32/steam          3MiB |
|    0   N/A  N/A     20573      G   ./steamwebhelper                                3MiB |
|    0   N/A  N/A     60958      G   ...atal,SpareRendererForSitePerProcess          2MiB |
|    0   N/A  N/A     67263      C   ...lib/plexmediaserver/Plex Transcoder        594MiB |
|    0   N/A  N/A     67662      C   ...lib/plexmediaserver/Plex Transcoder        684MiB |
|    0   N/A  N/A     67751      G   ...irefox/4848/usr/lib/firefox/firefox        176MiB |
|    0   N/A  N/A     68493      C   ...lib/plexmediaserver/Plex Transcoder        684MiB |
|    0   N/A  N/A     68726      C   ...lib/plexmediaserver/Plex Transcoder        594MiB |
|    0   N/A  N/A     69551      C   ...lib/plexmediaserver/Plex Transcoder        594MiB |
Screenshot from 2024-09-04 01-56-08
