I upgraded to a beta build of the server to fix a music issue I was having. I always hit the app.plex.tv to get my website. On my home page, I have recently added, recently played and Most played on Month. However, after the upgrade, Most played got removed and when I go into my Music library and recommended, its no longer there to be added.
I also run an older server on my nvidia shield and it’s there and shows up on the home page as well.
Did this get removed for some reason? Do I need to add something somewhere to get this back? I upgraded from 1.26.2.5797 (Public release). Will this be back in the 1.27.1.XXXX final release as I usually don’t install betas.
I checked this out and reset the whole thing… I then went back in and check them all to be on Home. This one is still missing… as well as others. Now I am not saying I have every one of those but I know (Just last release) I always showed Most played in (Month).
Want to make sure you are also on 1.27.1.5891? I did jump from 1.26.2.5797 to the beta build.
One thing to note… When I go to app.plex.tv I get web version 4.83.2 and when I hit my local machine 4.76.1 it is missing from both. So this seems to be caused by something within the server on builds 1.27.0 (Public) or 1.27.1 Beta release.
I’d wager that “recently played” is picked up from your database movie /played status. Try to manually set a movie as watched. Perhaps the database got fubar-ed and doesn’t think you watched ANYTHING, thus no “Recently watched” selection.
