Server Version#: Version 4.22.3
Player Version#: N/A
hi and sorry for my bad english, i’m french ^^
I’ve got a problem, my primary partition “/” is full and my biggest folder is the plex cache folder.
df -h return this :
df -h
Filesystem Size Used Avail Use% Mounted on
udev 16G 0 16G 0% /dev
tmpfs 3.2G 58M 3.1G 2% /run
/dev/md1 20G 19G 0 100% /
tmpfs 16G 20K 16G 1% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 16G 0 16G 0% /sys/fs/cgroup
/dev/md0 283M 64M 200M 25% /boot
/dev/md2 7.2T 6.5T 420G 94% /data
tmpfs 3.2G 4.0K 3.2G 1% /run/user/1000
tmpfs 3.2G 0 3.2G 0% /run/user/108
my goal would be to move cache (or all library folder) on /data/
i saw this post but i’m afraid to broke plex : Moving PMS 'Library'
if i copy “/var/lib/plexmediaserver/Library/Application Support/” in “/data/Library/Application Support/” chown it to plex:plex
i rename /var/lib/plexmediaserver/Library/Application Support by Application Support.bak
sudo service stop plexmediaserver
nano /lib/systemd/system/plexmediaserver.service
and point
Environment="PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR=/var/lib/plexmediaserver/Library/Application Support" to the newly created folder
Environment="PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR=/data/Library/Application Support"
start the service
Do you know if this action will work ?
ps : i thought too symlink but i don’t know how this work
Thanks for your help and sorry again for my english ^^
