Server Version#:1.15
Player Version#:2.1
Server on 1.15… movies 1080p on remote work for 5mns then hang…go out to home screen and play again, it will work for another 5mn and hang again… TV Shows 720p works perfectly without any issues…
The only solution i found is downgrading the server to 1.14… with that both movies and tv shows works perfectly…
If the server on 1.15 and your playin locally no issue at all, all work fine.
What it might be the issue here??
Server on Windows 10 with new fresh start
Player on apple TV remotely
